Old 12-14-2016, 12:14 AM   #29
Cldgin2
Cldgin2's Avatar
Drives: 2017 1LE SS
On the damn list !!! ��
Not that I care living in Vegas, but my heated steering wheel never seems to stay on, and may as well have them address the damn vibration in the door
'If one day the speed kills me, don't cry. Because I was smiling.' - Paul Walker
Cldgin2 is offline   Reply With Quote
Old 12-14-2016, 12:42 AM   #30
TheBigO
Mine has been in the shop since Monday for this recall and some other items...still waiting to hear what they found.
TheBigO is offline   Reply With Quote
Old 12-14-2016, 05:45 AM   #31
Burly
Burly's Avatar
Originally Posted by EFI Tuning View Post
I just looked at the bulletin. This one is a real beauty if you have to replace the line.
I would not go through the pain of this one unless the line absolutely needs to be replaced. If it doesn't I would just drop the transmission support, cut the bolt, and call it a day. I'll post the bulletin and procedure PDFs tomorrow.
Tim
Looking forward to your PDF, I've got access to a lift today.
Burly is offline   Reply With Quote
Old 12-14-2016, 09:24 AM   #32
EFI Tuning
EFI Tuning's Avatar
Drives: 2016 Camaro SS
Straight from the ACDelco TDS system. If you address the bolt itself before any issues have actually occurred I see zero reason to go through the pain of the actual line replace procedure. It just isn't necessary.
#52620-01.pdf
Transmission Fluid Cooler Inlet and Outlet Pipe Replacement (LT1 With M5U, With KNR).pdf
Tim
EFI Tuning is offline   Reply With Quote
Old 12-14-2016, 09:43 AM   #33
SSport16
SSport16's Avatar
Attachment 838770
Attachment 838774
Tim
Good to know, thanks! Mine is going in next week, hoping just a bolt cut and be done.
Old 12-14-2016, 09:51 AM   #34
EFI Tuning
EFI Tuning's Avatar
I'll be looking at mine today. If I see anything that would change my opinion I'll post here.
Tim
Old 12-14-2016, 11:23 AM   #35
EFI Tuning
EFI Tuning's Avatar
I have over an inch of clearance from the bolt in question and the line isn't going anywhere.
Old 12-14-2016, 12:12 PM   #36
Steve2150
Drives: 2016 Camaro 2SS, Red Hot
Disassembly question, was reading the PDF's and the front fascia comes off, will this break the factory paint seal or is the fascia pre painted separately. Looks like lots of removals, steering assembly etc. With them checking the date code gotta be more then the bolt making a mark on the pipe, gotta be something more.
Steve2150 is offline   Reply With Quote
Old 12-14-2016, 12:24 PM   #37
EFI Tuning
EFI Tuning's Avatar
The fascia removal will not affect the paint in any way. It is a pretty easy process.
My guess is the pipe can rotate out of alignment and can lead to the issue with the bolt. They probably improved the retention of the pipe orientation on the newer units.
The dealership will not be touching my car. Ever. LOL
Tim
Old 12-14-2016, 02:08 PM   #38
TheBigO
Mine had to be replaced...looks like it took 4 hours roughly.
Old 12-14-2016, 08:02 PM   #39
Burly
Burly's Avatar
Same here, there is some wiggle in mine but I don't see it touching at this point. I will check it when I can...
Old 12-15-2016, 12:14 PM   #40
gdgraph
gdgraph's Avatar
I know everyone situation will be different, and it all just depends, but my dealership just told me that they have done about 20 cars already and so far none needed the full replacement after being inspected so he said most people will not have to go through the really invasive replacement process. Scheduled my inspection for next week so well see how it goes...
gdgraph is offline   Reply With Quote
Old 12-15-2016, 03:36 PM   #41
SSport16
SSport16's Avatar
Tbis is what I am thinking...mine is going in next week as well, fingers crossed!
Old 12-15-2016, 03:57 PM   #42
VelvetHammer
VelvetHammer's Avatar
Drives: 2016 Hyper Blue 2SS, A8, NPP
Early production models are the ones needing replacement. If the production date on your car is after mid-June of 2016 you should be OK. That is the date code being checked on the replacement parts. Verts are not included, they don't have the diff cooler.
VelvetHammer is offline   Reply With Quote
