Old 07-20-2016, 08:39 AM   #29
Rsblueblood
Kywildcats
Rsblueblood's Avatar
Drives: 2020 2SS shock and steel (shocker)
Have you notice not even a reply from customer service on these threads. They really care.....
Rsblueblood is offline   Reply With Quote
Old 07-20-2016, 09:06 AM   #30
classicrockr
Pills are for Pansies
classicrockr's Avatar
Drives: 2023 2SS Red Hot Vert Camaro
Wonder if it could be claimed that this is causing a driving hazard and possibly use the lemon law to get rid of it until they fix the issue?
classicrockr is offline   Reply With Quote
Old 07-20-2016, 09:21 AM   #31
bballr4567
Drives: 2016 Camaro 1LT M6
All they ask for is for you to give them information and they "pretend" to get you help. The best service is to have a great relationship with your dealer. That's the easiest way to get help. If they were to monitor all the "issue" threads here and on every other forum they would need a small army to cover many of the baseless complaints.
Regardless, as I said in the other thread, the easiest way to stop this from happening is to take your AC off of LO. If you set it at LO the car tries to get the cabin so cold it will condensate on any window.
Mess with the temp and you'll get the fogging to go away a fair bit.
bballr4567 is offline   Reply With Quote
Old 07-20-2016, 12:50 PM   #32
Rsblueblood
Kywildcats
Sorry that's not the answer, even with it set on 75 still fogs up. As long as there is air coming out of the vent by the windshield and it's cold air the window will fog up. This isn't rocket science.
Old 07-20-2016, 01:31 PM   #33
KenH.
KenH.'s Avatar
Drives: 2016 2SS M6 NPP MRC
I think a proper application of rainx will fix this for you. Even though for a week and a half my car has been in the shop I live in a really humid area and have not had any condensation since treatment.
Make sure your windshield is stripped of waxes and what not for best results. I like to use very soapy water and steel wool. Pulls literally everything off the windows. If you plan to use steel wool read up on how its done and the type to use (0000 i think is the finest you can get) so you don't go damaging your windshield. A less is more approach with a handful of steel wool is a good idea.
KenH. is offline   Reply With Quote
Old 07-20-2016, 03:38 PM   #34
Wheel Team 6
Wheel Team 6's Avatar
Fogging windshield
Please see my latest post in the general thread.
http://www.camaro6.com/forums/showth...=454169&page=6
I had my windshield cleaned, prepped, rain x fog x applied by my window tint shop and it hasn't helped.
Wheel Team 6 is offline   Reply With Quote
Old 07-20-2016, 10:09 PM   #35
bballr4567
No, it's not rocket science but it does help if you adjust the temperature but it doesn't make it go away completely.
Old 07-21-2016, 01:20 AM   #36
coastal_carolina
Hung Like a Republican
coastal_carolina's Avatar
Drives: 2016 Garnet 2SS Cpe
Post
RainX regular and RainX anti fog has not helped this issue for me. I realize that you are in a different state but not really a different climate. We must be getting more humidity in SC than NC is right now, or my windshield vent leaks worse than yours.
All of my windshield fogging is on the outside.
**Just a note, RainX says the anti fog is only for the INSIDE windshield, and the regular RainX is only for the OUTSIDE windshield. They recommend not deviating from this.
I regularly use their green (warm weather) and orange (de-icer) RainX windshield washing fluid. The green constantly applies RainX when using it. Very convenient. They also make a washer fluid additive.
Also, my family has used Bon Ami for years to clean and strip the outside windshield. I only used it a few times on my GTO. Safer alternative IMO than steel wool. I just recently found a discussion on others using it on windshields:
http://www.corvetteforum.com/forums/...indshield.html
You can also Clay Bar your windshield to strip and clear. RainX has even got in on the craze and created a kit:
https://www.rainx.com/product/glass-.../#.V5Bw77zEyrU
PROUD OWNER (7-5-16) of a 2016 2SS,Garnet,Kalahari,A8,Sunroof,Mag Ride,NPP,
Nav,Suntek CXP 70% tint,Suntek PPF paint protection
**Previous ride: 2006 Spice Red Metallic A4 GTO
High end vs low end radar detectors
RadarBusters.com
GuysOfLidar.com
RadarDetector.net
Mine: v3.826 V1 (2006)
**2016 SS police stealth
**2015 BMW M4 vs 2016 SS Camaro MT Head 2 Head
**Fav cars: Vettes [C2,C3,C7], SS Camaros [1st Gen,02,6th Gen], M6 BMW, Aston DBS
**Coastal_Carolina over @ LS2GTO.com
SpiceyGTO over @ CorvetteForum.com
coastal_carolina is offline   Reply With Quote
Old 07-25-2016, 10:34 PM   #37
Brusah
Brusah's Avatar
Drives: Hyper Blue 1SS 6MT
I stripped the inside and outside of my windshield using isopropyl alcohol and microfiber cloth, then cleaned with my favorite foaming class cleaner, then applied RainX and RainX anti-fog. Still fogs on outside even if it's 80 and have A/C set to 80 which completely defeats the purpose of A/C. I even tried turning heat and defrost on and that took forever to defog the window.
Brusah is offline   Reply With Quote
Old 07-26-2016, 08:31 AM   #38
Stex
Drives: 67 goat, 69 goat ram air III
As said a towel will block the vents. May want to try the no slip drawer liner stuff. Lets some air thru but may block enough to limit the fogging. ???
Stex is offline   Reply With Quote
Old 08-03-2016, 11:21 AM   #39
Bradl1982
Drives: 17 Camaro 2SS
Has anybody brought this up to their service department and gotten any other answer other than "it's normal"? Dealing with this every morning is getting really annoying.
Bradl1982 is offline   Reply With Quote
Old 08-03-2016, 11:23 AM   #40
vet757
vet757's Avatar
Drives: ^^^This
Mine does it sometimes then it goes away after a few minutes.
vet757 is offline   Reply With Quote
Old 08-03-2016, 11:37 AM   #41
TMasticTB91
Tampa Bay Camaros
TMasticTB91's Avatar
Drives: '16 Hyper Blue 1LT
Me, but I also had gone in to the dealership for a separate HVAC issue where I lost A/C for one day (lovely in Florida). My HVAC control module was found to be faulty, just waiting on them to install it so I can get my friggin' car back.
2016 Camaro 1LT | V6 | A8 | Hyper Blue
TMasticTB91 is offline   Reply With Quote
Old 08-03-2016, 11:42 AM   #42
vet757
vet757's Avatar
Drives: ^^^This
This happened to me the other day. My AC was not working for a few minutes. I pulled over restarted the car and no more issues since then. I wonder if my HVAC module is faulty too.
