06-24-2016, 11:44 AM | #1 |
Drives: 2016 2SS Join Date: Mar 2014
3.9 Chevy gears
06-24-2016, 11:56 PM | #2 |
Drives: 1987 Z28, 385cid, '16 Camaro 1SS Join Date: Feb 2016
I'm not sure the 3.91 gears would be worth it over the already stock 3.73's. I will seriously consider doing 4.10's however. The down side is that what I've read about the labor costs involved with swapping rear gears in the gen5's. Total swap costs seem to be around $1400-1800 do to having to drop the entire center section. Either way, it's something I'll seriously think about over the next few years as a 3.73 to 4.10 rear gear swap would easily be good for .20-.30 in the 1/4m. Add that with decent 305-315 series rear tires, maybe some rear suspension work, a good cat back exhaust, CAI and possibly a ported throttle body (trying to avoid a warranty voiding tune), all this should be good for 20-25rwhp, better traction and possibly .50-.60 off the 1/4m time, bringing them down to 11.70-11.80 range for the M6.
Just my thoughts.
02/23/16: 1100, 03/16/16: 2500 # TGHR6N
03/16/16: 2500, 03/18/16: 3000 TPW : 4/11/16 04/8/16: built & VIN 04/11/16 - 04/28/26 : 4B00 Bayed QC hold, 04/29/16 : 4200 Rail yard '16 1SS 6M, black with jet black interior, split spoke gray machined faced wheels, and black front/rear bowtie emblems. |
06-25-2016, 12:23 AM | #3 | |
But I might just wait for the intake and 1LE suspension parts. But I'm impatient. I already 0-60 in 3.6 with just deleted mufflers. Imo With all the mods you listed should be low 11s I'm getting my rims and tires next week and hopefully I see those drop my times. |
08-11-2016, 03:55 AM | #4 |
Drives: All things Turbocharged Join Date: Dec 2010
Do we even know if the old Camaro5 rear gears are the same as in the new rear?
08-11-2016, 07:34 AM | #5 |
Bump in the night
Drives: '84 Monte Carlo SS, '15 Optima Join Date: Oct 2015
Nobody believes 3.6 until we see some time slips, spoofing the timer by breaking loose the tires when you hit 2nd doesn't count.
08-11-2016, 12:50 PM | #6 |
Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
08-11-2016, 12:52 PM | #7 |
08-11-2016, 02:44 PM | #8 |
Bump in the night
Not trying to bash just keeping things in perspective, the ZL1 is rated at 3.5, and all you had when you got that number was straight pipe exhaust.
I just have a hard time believing your car has 150hp+ over what it's rated at to, and to get that number with skinnier tires.
08-11-2016, 02:49 PM | #9 | |
08-11-2016, 11:37 PM | #10 |
GM repeat offender...
Drives: 16 2SS Join Date: Dec 2014
You should go with the "3.9s". You will EASILY pull 3 flats!
'16 2SS, Summit White. A8. MRC. NPP.
Ordered:09/03/15. Received 12/22/15 INCOMING: ‘22 ZL1, Satin Steel. A10. PDR. Ordered: 03/02/22. |
