06-19-2016, 07:04 AM | #1 |
Drives: 2012 Camaro LS Join Date: Jul 2015
Manual transmission on the V6
Does anyone know what yhe bolt patter is on the engine of the V6? Is it the same as the LFX in the 12-15? I'm curious because if it is the same then their is the possibility of using the bellhousing off the new V6 on the older models so a TR 3060 can bolt up to it.
Im just trying to find a better and stronger solution for my car than the Aisin AY6 since im pushing well beyond it's rated power. |
06-26-2016, 08:49 PM | #2 |
Drives: Camaro 6 - Summit White E/28 Join Date: Jun 2016
12648842
Has BCD of 83mm, spacing of 48,42,45,45,45,48,42,45 |
06-29-2016, 08:01 PM | #3 |
07-08-2016, 07:09 PM | #4 |
BCD is bolt circle diameter.
and the spacing is in degrees. 12648842 is a part number |
