08-14-2022, 03:43 PM | #15 |
Drives: Canadian 2019 BLACK ZL1 Join Date: Feb 2020
08-14-2022, 04:25 PM | #16 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Katech, the ones who make a way better oil pump than GM ever will, has said that they have tested every updated oil pump for the LT4 and they all fail. In some sort of way.
So that means GM knows that their oil pumps for the LT4 are garbage but instead of fixing the issue once they put a bandaid on it. |
08-14-2022, 04:47 PM | #17 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
08-14-2022, 08:07 PM | #18 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
I believe the same oil pump has been/is used in other GM cars and trucks, so the overall failure rate is likely much smaller than the context presented in this forum. If that is the case, I wonder if it is the use of this pump on the ZL1s and how they are driven which contributes to the failures we see here. Just pure speculation on my part.
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
08-15-2022, 03:08 PM | #19 | |
08-15-2022, 03:12 PM | #20 |
08-15-2022, 05:30 PM | #21 | |
What was said above is irrelevant because those are different engines if they're using the same pump. Part.of the pump failure issue is the guide tensioner. That would be different on a non-LT4 engine. |
08-16-2022, 12:07 AM | #22 | |
Drives: 2019 ZL1 Join Date: Mar 2019
It’s going in my new engine as well. The truck pumps have been used for quite awhile as replacements and I’m not aware of any failure on those.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
08-16-2022, 07:52 AM | #23 | |
You know what the ignorant says to you ? So start to respect others with humility…you know where the issue is … |
08-16-2022, 08:16 AM | #24 | |
Petro-sexual
08-16-2022, 01:12 PM | #25 | |
Drives: 2018 ZL-1 Join Date: Jan 2018
I have been on this forum for 4 years, and I have never heard of this problem from people who have had actual oil pump failures. I'm pretty sure I have read the entire oil pump thread. Can you point to a post on the forum about such a failure? The oil pump failures on the thread all seem to be cracking failures of the outer ring inside the oil pump. The vanes from the pump rotor eventually snag on the crack, and the inside of the oil pump gets torn up. I looked at the LME video about their tensioner replacement, and it seems like a normal upgrade for a racing engine, but absent even one post about this on this forum, I'm a little perplexed about this aspect of oil pump failures. |
08-16-2022, 01:48 PM | #26 | |
Timing chain tensioner. https://latemodelengines.com/lt-timing-chain-guide.html
08-16-2022, 01:51 PM | #27 | |
Its a well known issue. https://www.autoserviceprofessional....r-chevy-camaro
08-16-2022, 02:10 PM | #28 | |
You state that it is a well-known issue. I just don't see these cam chain types of failures on this forum. |
