Old 09-08-2021, 08:58 AM   #1
17MaroSS
Drives: 17 2SS 6sp
Brake booster msd
I can't for the life of me get this brake booster line back into the MSD intake manifold. Any help
Greatly appreciated
FOR SALE 17 2SS 6spd h/c/i/fbo
17MaroSS is offline   Reply With Quote
Old 09-08-2021, 09:01 AM   #2
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
i did it with having the msd off so i can see what i'm doing, easier to maneuver that way but it also never put up a fight on me from what i can remember. looks like you broke something from the looks of that pic though, i could be wrong.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 09-08-2021, 09:09 AM   #3
Puddin
Looks like you actually pulled the fitting out of the manifold itself.
Old 09-08-2021, 09:12 AM   #4
17MaroSS
Drives: 17 2SS 6sp
That's exactly what happened. Any ideas on how to get that fitting off so I can stick it back in the manifold?
Old 09-08-2021, 10:13 AM   #5
Puddin
I'll be honest I don't think that fitting is salvageable. If you do get it back in more than likely it will leak. You may be better off doing your own custom fitting and booster line at this point.
Old 09-08-2021, 11:20 AM   #6
17MaroSS
Drives: 17 2SS 6sp
Ok thanks
Old 09-08-2021, 04:39 PM   #7
BruceWayne1LE
BruceWayne1LE's Avatar
Drives: 2018 Camaro SS 1LE M6
It’s salvageable. I did the same thing. First separate the fitting from the hose. Put a *VERY SMALL AMOUNT! of rtv of those teeth. Wood/rubber mallet and lightly tap it in. Give the rtv some time to dry then reinstall the hose BEFORE installing the manifold.
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ
BruceWayne1LE is offline   Reply With Quote
Old 09-08-2021, 05:25 PM   #8
17MaroSS
Drives: 17 2SS 6sp
that fitting won't come out and we damaged it trying
Old 09-09-2021, 07:06 PM   #9
17MaroSS
Drives: 17 2SS 6sp
Update. I ordered these fittings and will attempt to retap the manifold. Any advice?
Old 09-22-2021, 09:54 PM   #10
17MaroSS
Drives: 17 2SS 6sp
Update. Great success with the new fitting (pictured above). I used a 1/2" 14 NPT tap to make the brake booster hole in the back of the manifold bigger to accurately accept the new fitting. I was very nervous attempting this at first but it went in and did the job very nicely. I removed the old busted plastic fitting off of the hose and it slid in the new fitting and locked in place perfectly.
Old 09-23-2021, 12:36 AM   #11
BruceWayne1LE
Nice job on tapping a new line. The OEM fitting is BS. You have to push the collar toward the teeth while also pulling the hose. Feels like a 3 handed job. But now you have me thinking of tapping a proper fitting for reassurance.
492WHP 473WTQ
Old 09-26-2021, 11:12 AM   #12
s346k
s346k's Avatar
Drives: like an old lady
once the brake booster line goes in that fitting on the msd manifold, it becomes one with the manifold. i sold one of my msd manifolds with that line still attached bc i didn't want to destroy it attempting removal. good news is, it's just a vacuum line. most any idea will work.
Old 07-02-2022, 04:32 AM   #13
RobbyBeefcake87
RobbyBeefcake87's Avatar
I'm about to install an MSD for the first time. Is the MSD supposed to bring that fitting or is that something that came from the stock IM and transferred to the MSD.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler.
2018 Colorado zr2 - zr2 sport bar, showcase spare tire.
2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace.
2017 Corvette Grandsport (sold) - untouched.
2006 GTO (sold) - iat relocation, air box mod, monero side marker lights.
RobbyBeefcake87 is offline   Reply With Quote
Old 07-02-2022, 05:18 AM   #14
s346k
s346k's Avatar
if i recall, the msd has the fitting installed already, waiting to accept your factory brake booster line.
be warned: once you connect your stock line to the msd fitting, it isn't coming apart again. i simply bought another line from gm to keep around in the event i need to swap the msd.
although the LT2 manifold i have sitting around also has a brake booster line stuck in it.
