07-28-2021, 07:23 AM | #1 |
Drives: 2021 ZL1 6MT Join Date: Jan 2017
What's the fastest you have gotten your car to
No way a ZL1 goes 198mph...but I have seen 183
07-28-2021, 07:48 AM | #2 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
About 183 as well. Ran out of room.
07-28-2021, 07:50 AM | #3 |
Petro-sexual
The 198 is a 2-way average GM set and was not the top speed they recorded for the car. That average was also, if I recall, done at recommended tire pressures and stock alignment settings. They were able to exceed 200 through max tire pressure and alignment changes. So - yes way.
07-28-2021, 07:52 AM | #4 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
I can't confirm it but its hard to imagine that Chevrolet claims 198mph but they will only do 183mph. I could understand a few mph but not 15mph, I've just never seen any manufacturer be that far off. Something doesn't make any sense there. I could also see a 1LE not doing 198mph due to the downforce.
07-28-2021, 07:55 AM | #5 | |
Petro-sexual
07-28-2021, 08:05 AM | #6 |
There was room but the number was advancing very slowly…and it was over 4000 feet altitude, and on 91 octane and tire pressure was 41psi
07-28-2021, 08:06 AM | #7 |
Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
regular zl1 with the low wing has top speed advantage. ZL1 1LE, no way its breaking 190 mph
07-28-2021, 08:45 AM | #8 |
Drives: Turbo 6.2 Join Date: Feb 2019
168 at the half mile. She was pulling but the track ended. Its a lot of abuse on a FI engine that relies on Meth LOL
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
07-28-2021, 09:14 AM | #9 |
Drives: A10 ZL1 Join Date: Mar 2018
174
07-28-2021, 09:25 AM | #10 |
4000ft altitude has a lot to do with it and 91 octane wasn't helping any either. Car makes a lot less power there with those two factors. I'm sure the last few mph comes slowly but you had two factors working against you.
07-28-2021, 09:28 AM | #11 |
Petro-sexual
+1. Less air density is less power. The owner's manual also states the car was tuned for 93, so it can get into pulling timing pretty quickly.
07-28-2021, 10:28 AM | #12 |
Drives: 2019 ZL1 Join Date: Mar 2019
Ive hit 187 quite easily and i'm pretty sure I can break 200, but I am not stock.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
07-28-2021, 10:28 AM | #13 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
07-28-2021, 10:40 AM | #14 |
Look how humble and reserved he is all of a sudden
