09-26-2022, 01:20 PM | #85 | |
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE Join Date: Feb 2020
I called TREMEC today to see when they would have their fluid in stock. They don’t have any and the place that use to make it for them doesn’t anymore. They have a new company trying to make it. |
09-27-2022, 09:54 AM | #86 |
Drives: 2018 ZL1 Coupe NFG M6 Join Date: May 2017
I've been running Royal Purple since day one with plenty of track use, no complaints.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School 2017 Colorado Z71 <- Daily 2018 ZL1 M6 <- Not Daily |
09-27-2022, 10:04 AM | #87 |
Drives: '17 ZL1 Join Date: Jul 2016
Personally, I'm not a fan of Royal Purple. It seems okay under normal conditions, but I found on the race track I would have to wait longer than other fluids on the downshifts. When you're chasing tenths on a road course, that doesn't work. Transmission temps were also higher vs OEM fluid and Tremec fluid. I ran one weekend with Royal Purple and immediately drained it.
Tremec recommends Pennzoil Synchromesh (since their fluid is no longer available). I've been running the Pennzoil Synchromesh for several track events now. It's maybe not quite as good as the Tremec formula, but it's pretty darn close. If you currently run Royal Purple, I'd encourage you to try some alternatives. I bet you don't go back.
09-27-2022, 10:07 AM | #88 |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
No issues in 7k miles with Amsoil Signature ATF fluid here in Phoenix. Transmission shifts like butter on and off track.
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
09-27-2022, 10:22 AM | #89 | |
09-27-2022, 10:31 AM | #90 | |
I have a few of my laps posted on the Best Track Times thread. PittRace is my closest track, so that's a good reference. The VIR and Summit Point laps I have posted aren't bad either I suppose.
09-27-2022, 01:04 PM | #91 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
I called and asked TREMEC a few years back about the -6060 and what they recommend. Specifically about the ATF spec from GM vs their HP Fluid.
He wouldn't speak to why GM spec'd ATF for the -6060, but he did tell me all the reasons they recommend HP-MTF. So for the last few years, I have been running nothing but the TREMEC fluid...then the plant burned and you couldn't get it any more. When I called to ask for recommendations on replacement fluid, they said Pennzoil Synchromesh. One of the benefits, BTW is because it's not ATF, it doesn't have the expansion properties that require you to fill and then drain some of the fluid out. He said a very common failure is filling the unit up with ATF, not draining the required amount and developing leaks in seals due to case pressure.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
09-27-2022, 02:47 PM | #92 | |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
09-27-2022, 08:49 PM | #93 | |
Here is a step by step: https://www.camaro6.com/forums/showthread.php?t=537762
2017 HBM SS 1LE
