Old 07-08-2020, 03:35 AM   #1
Ceasar0521
Drives: 2018 Chevrolet Camaro SS
AFM VALVE DELETE
Hey I've recently got a custom exhaust for my 2018 Chevy Camaro SS I was wondering if there's a way for The CEL to not come on since the AFM valve was deleted
If anyone can help please reply
Ceasar0521 is offline   Reply With Quote
Old 07-08-2020, 06:46 AM   #2
njweatherman
Drives: 2018 Camaro 2SS, redline edition
Unlike the NPP valves, the AFM valves are checked at every startup. See below for what people have done:
1. Get a custom tune.
2. https://www.camaro6.com/forums/showt...=473084&page=3 (see post #42)
3. Buy an X pipe that has the AFM valves (Flowmaster) or dummy AFM valves (AWE).
Hope this helps.
njweatherman is offline   Reply With Quote
Old 07-08-2020, 09:02 AM   #3
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
sell the SS, get a V6 RS. The afm valves are mechanical only and can be played with or removed any way you like without bothering anyone.
Old 07-08-2020, 09:07 AM   #4
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Hopefully you still have the actuators. You can reconnect the actuators to the wire harness and then tie them up into an out-of-way location under the car. The actuators don’t have to be connected to the exhaust.
Old 07-09-2020, 07:39 AM   #5
ember1205
Hot Camaro
ember1205's Avatar
Why would they sell the SS to get a V6 model? This makes -ZERO- sense.
This won't work correctly and WILL cause issues with the engine. The AFM valves close when the engine switches down to 4CYL mode and needs additional back pressure to run properly. If you don't have the car tuned to disable the cylinder drop mode, the engine will switch to 4CYL and reduce air intake while expecting a bump in back pressure. That won't be there because, although the computer switched the valves to the closed position, there are not valves to actually close and increase the back pressure.
The engine will not run correctly and a variety of things could occur like loss of power or even damage to the engine.
Old 07-09-2020, 09:32 AM   #6
cellsafemode
I mentioned exactly why. The v6 has mechanical-only afm valves that can be modified, removed etc without causing any kind of ecu error codes unlike the SS.
It makes 100% sense in resolving the issue.
Old 07-09-2020, 09:38 AM   #7
ember1205
Hot Camaro
ember1205's Avatar
Yes. Sell a high performance vehicle for a mid-level performance once, losing thousands of dollars in the process, instead of having the AFM disabled by a tune or AFM disabling device.
Sorry, couldn't disagree more with your approach.
If you insist on the "sell the car" stance, then sell it in favor of an SS with M6 transmission which doesn't have AFM valved on it in the first place.
Old 07-09-2020, 09:50 AM   #8
VQ35DE
Drives: 2013 / 2SS / RS / L99
I have a question. Do both the V6 and V8 M6 transmission cars NOT have the AFM valves at all or are the AFM valves on the exhaust system BUT just not activated by the software on M6 cars ? Who knows for sure ?
VQ35DE is offline   Reply With Quote
Old 07-09-2020, 09:57 AM   #9
cellsafemode
The tuning will impact the warranty (if discovered) on the entire drive train. AFM removal on the v6 will not. So you potentially risk even more sticking with the SS.
My solution is sound. They'd be better off with the V6.
Old 07-09-2020, 09:58 AM   #10
ember1205
Hot Camaro
ember1205's Avatar
There are no valves, and thus, no actuators (on the V8, at least).
Old 07-09-2020, 09:59 AM   #11
ember1205
Hot Camaro
ember1205's Avatar
Given that the car is a 2018, your solution is NOT sound. The warranty is drawing to a close...
Old 07-09-2020, 10:26 AM   #12
cellsafemode
Given the SS's history with the A8 ...that warranty is still plenty important to have intact for the full term.
He could still probably get a good amount for selling it though before the used car market collapses.
Pick up a sweet new 2020 v6 and goto town on the exhaust without tuning.
Old 07-09-2020, 10:29 AM   #13
caSStro18
Drives: 2018 Camaro SS
Yeah...I'm pretty sure the OP bought the car for V8. Trading it for a V6 just for the fact that the AFM valves can be disconnected without throwing a CEL is ludicrous. A tune will solve the problem. If the car is still under warranty and the OP doesn't want to risk losing that, they can simply wait. Or, tune it and hope it is not discovered. I'm wondering if installing an AFM disabler will solve the problem? I'm thinking it may not unless the valves are reinstalled and plugged in though.
caSStro18 is offline   Reply With Quote
Old 07-09-2020, 12:03 PM   #14
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Manual cars don’t have AFM at all and the exhaust don’t have the valves either built into them either
2022 2SS 1LE - Cold Air Inductions Elite Carbon CAI
2016 1LT v6
- Totaled
Happiness: Infinite
