03-30-2023, 07:55 AM | #1 |
Headlight Leveling Fuse
Hello,
What is the F38 Headlamp leveling fuse for?
2018 Camaro 2.0 LT Turbo, Conversion to ethanol E85, K&N Typhoon filter, Front Bumper and rear diffuser ZL1/1LE, LED headlights |
03-30-2023, 08:18 AM | #2 |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
A headlamp levelling system adjusts the height of the cut-off line to the load condition of the vehicle. This is supposed to avoid blinding oncoming traffic when the vehicle is loaded. Manual and automatic headlamp levelling systems are installed in current vehicle models.
03-30-2023, 10:49 AM | #3 | |
Drives: 2018 ZL-1 Join Date: Jan 2018
03-30-2023, 02:25 PM | #4 | |
Here are the photos of the headlights, they don't have motors or anything electronic. On my Mercedes, when I turn on the headlights, they go up, down and level. There is no similar system on the Camaro.
03-30-2023, 02:51 PM | #5 | |
Ya... IDK... I just looked up what Headlight Leveling was. Maybe they use the same fuse box and wiring harness in other vehicles and in other vehicles that fuse/option is used. (Just a guess).. Pull the fuse and drive that car at night, see what it does. Don't forget to report back... |
03-30-2023, 03:30 PM | #6 | |
Could it be the fuse that turns on the headlights when you open the doors with the remote? If you have the same F38 fuse on your car, remove it and see if when you open the doors with the remote they come on!
03-30-2023, 04:27 PM | #7 |
This might explain it. If I'm looking at your pic attached and the same fuse box in that document F38 is not used.
03-30-2023, 06:13 PM | #8 | |
Doesn't the fuse turn on the headlights when the doors are opened with the remote? I replaced my headlights with Vland LEDs, there is a harness to couple with the F38 fuse, with or without the harness it does not change anything, the headlights work, but do not light up with the remote, just the turn signals.
03-31-2023, 03:19 PM | #9 | |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
I'm looking at your picture and I have a few observations. My car is a 2017 and it's an SS but the fuse box looks the same. I have a fuse tap in that same slot for a dash cam. The pin in the fuse slot that is on the left is the switchable hot wire. If I'm figuring it correctly, you have the tap in 180 degrees off. The current will go through the lower fuse and then back through the upper fuse to the red wire. That would mean that the lower fuse is carrying current for both circuits. If it's reversed, the lower fuse only handles the current for the original circuit and the power will go through the upper fuse to the red wire separately. You could test this by pulling the lower fuse and seeing if you are still getting current to the red wire. I hope I got that all correct.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
04-02-2023, 09:20 AM | #10 |
Drives: 2020 Camaro 2SS Join Date: Aug 2009
