03-27-2023, 05:46 PM | #15 |
Iron fist, lead foot
Drives: 2003 Mustang Cobra Join Date: Jul 2013
I do find it odd that so many will tell their anecdotal "evidence" that the 2.7L L3B equipped Silverados/Sierras are just sitting on the lots not selling. While the F-150's 2.7EB has no problem selling. It's 335/400 is also torque-wise less impressive than the 310/430 offered by the gm unit.
Is it just the cylinder count that throws everyone off? Because obviously the displacements are almost identical 2.767L for the L3B and 2.700L for the EB.
03-27-2023, 06:05 PM | #16 | |
Long live the ICE...
Drives: 2020 Camaro ZL1 Join Date: Jul 2021
2020 ZL1 in Satin Steel Metallic.
03-27-2023, 08:12 PM | #17 | |
Drives: 23 LT1/22 Colorado TB/69 Chevelle Join Date: Jun 2006
03-27-2023, 08:14 PM | #18 | |
03-27-2023, 08:33 PM | #19 | ||
Drives: 2023 ZL1 A10 Join Date: Nov 2021
Gearhead SS , I take it you work for Chevrolet, can you tell me more about the engine trans. If I remember correctly,I had a 2005 Tahoe made in Texas ,was or is there a plant that assembles this truck . Do you work there. Thanks
2023 ZL1 A10 Shadow Gray Metallic
03-29-2023, 08:25 AM | #20 |
Drives: 2023 Camaro LT1 6.2 MT6 Join Date: Jan 2023
03-29-2023, 08:39 AM | #21 |
03-29-2023, 08:49 AM | #22 |
No, I work at a dealership. The Tahoes are still made in Arlington, Tx but 1500 trucks come from Mexico, Ft. Wayne Indiana or Canada.
03-29-2023, 10:09 AM | #23 | |
Drives: '23 1LE, '18 Canyon, '87 325i Join Date: Jul 2022
I can see the benefits of a 2.7L turbo in the smaller trucks, but even then, they don't get better mileage. Lower down torque is a lot better, the 3.6L is a solid engine, but needs lots of revs to build decent power, not great for towing anything over 6,000lbs. Even the E30 = 2500 lbs trailer (5,200 lbs) was a challenge on mountain roads. |
03-29-2023, 10:44 AM | #24 |
Shadow Gray '19 ZLE M6
FWIW, the 2.7 is not only used in trucks -- it's in the CT4-V (non-BW) and (I believe) the top trim CT4 model (maybe Premium?)
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
03-29-2023, 10:55 AM | #25 |
Seems to be good so far. We'll see how they do with more time and mileage on them though.
We don't see many of them in here with major issue. We had one that was eating oil like crazy and found it was due to a manufacturing defect on the block where one of the surfaces wasn't fully sealing because it wasn't completely flat. GM replaced the engine and it's all good now. |
03-29-2023, 11:40 AM | #26 |
i testdrove one a few weeks ago and wasnt a fan also drove a 5.3 and a 3.0 diesel turbo and ended up with a 23 rst silverado 1500 5.3 2wd
03-29-2023, 12:27 PM | #27 | |
Care to elaborate on what exactly you didn't like and what you did like about each powerplant? The 5.3L holds the HP advantage, that's for sure, but it's 383lb-ft of torque at 4100rpm is topped fairly handily by the other two. Not just in output but in time of delivery. The L3B delivers its 430lb-ft @ 3000rpm while the LZ0's 495lb-ft happens at only 2750rpm.
03-29-2023, 12:37 PM | #28 |
wasnt a fan of the turbo lag and it felt underpowered for the size of the truck im sure the gas mileage is fine but i will be towing my camaro and trailer later and i had a cruze with a baby turbo and it below out about 100,000 miles dont want that to happen again
