01-18-2011, 12:11 AM | #1 |
Drives: 1996 gmc ecsb 408 ci SC 4l80e Join Date: Sep 2009
Wider rear tires?
What options do i have? i would like to get something wider mainly for a more agressive look. Is there a downside to doing this? Is it even possible to get a wider tire on the stock wheel?
2010 2ss rs |
01-18-2011, 12:23 AM | #2 |
E.B.A.H.
Drives: you wild... Join Date: Mar 2007
Location: In the happy padded room wearing a jacket that makes me hug myself...
You can go wider on the tires for a slightly larger contact patch and aggressive look if you want, but not by much. Once you get to the 305 and 315's, you will actually loose performance among other things because the contact patch will change from the tires being squished onto the wheel.
IIRC, 295 tires are about the maximum width you can go before people have started having issues. If you stay at 295 or below, there isn't a downside that I know of, except for maybe tire prices might jump a little. |
01-18-2011, 02:46 AM | #3 | |
01-18-2011, 04:22 AM | #4 | |
Drives: 2010 Camaro LS-M6 67 Chevelle Wgn Join Date: May 2009
Here`s the link to that discussion, I`m sure one of those who believe it`s OK to run 315`s on stock rims will also respond to this thread too. http://www.camaro5.com/forums/showthread.php?t=119170 |
01-19-2011, 03:15 PM | #5 |
So if i have the rims widened to 10.5 i can run the 315's safely? they wont rub? has anyone done this?
01-19-2011, 06:56 PM | #6 |
Warehouse 13 Survivor!!!!
Im running 315's on an 11" wheel with no rubbing issues, closest it comes to rubbing is the inner liner but there is easily 3/4" to spare. I can't safely answer whether or not widening the wheel will make it possible since you would be changing the offset by widening it. Other people have had them widened though so do a search for it.
01-19-2011, 07:09 PM | #7 |
Drives: 2010 2ss/rs M6 Join Date: Nov 2010
What's the proper side wall to go with a 295/??/20?
01-19-2011, 08:24 PM | #8 |
E.B.A.H.
There's a sticky up top from Nineball who has a table to figure out what size tires you want.
@567234ta, I am have 315/25/22's on my car with no issues and no fabrication at all. My car is also lowered, still with no issues. |
01-21-2011, 12:20 PM | #9 |
Okay great, i know a place that does a great job at widening the wheels. Mindz- your car looks awesome!!
01-21-2011, 06:59 PM | #10 |
Drives: Grey Beast Join Date: Jul 2009
I am running Pirelli 295/40ZR20 on stock rims and they look and perform great!!!
2SS/RS A6 and some go faster parts
01-21-2011, 07:43 PM | #11 | |
E.B.A.H.
Thanks 567234ta!
Here you go if you're looking to retain the same height as the stock wheels/tires. This is the recommended tire sizes. |
01-21-2011, 08:20 PM | #12 |
01-22-2011, 06:58 AM | #13 |
01-23-2011, 02:50 PM | #14 |
Drives: 2010 camaro 2ss, blown Join Date: Jan 2011
wider tires
I need a tire for the drags that I can also run on the street. Im hopping for 10 to 10.5 inch width. Any suggestions? I want to stay with stock rims if possible
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
front tires on rear wheels | TommyTSquared | Wheels and Tires Talk Sponsored by The Tire Rack | 14 | 01-01-2011 10:53 AM |
WTB POLISHED 20" REAR WHEELS WITH TIRES | JohnnyrSS | Wheels / Tires | 0 | 10-07-2010 10:32 AM |
Can you put rear wheels and tires on the front? | GQ4Life | Wheels and Tires Talk Sponsored by The Tire Rack | 14 | 09-01-2010 11:05 PM |
11,000 miles and I need to replace rear tires! | sewwhut | Wheels and Tires Talk Sponsored by The Tire Rack | 8 | 03-13-2010 05:00 AM |
Any Body Want to Buy Me A Set of Rear Tires for 2SS? | Scott@Bjorn3D | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 38 | 08-15-2009 08:07 AM |
