08-15-2022, 12:28 PM | #1 |
Drives: Chevrolet Chevy Join Date: May 2022
Tips for Long-Term ownership
So I was able to get my hands on a 1SS 1LE that someone backed out of a few days ago. I do plan to keep this car for many, many years as we all know the days of V8 Manuals, and the Camaro especially, are numbered.
With that being said, I'd like some feedback on my current plans to help the longevity of the car. The car has the Mishimoto oil catch can coming, and the car was just dropped off at the shop for front end PPF. Once I get it back, I'm polishing the rest of the car and coating it with graphene. Still up in the air about whether or not I should get PPF for the roof. Any of you guys have rock chips on your roofs? I'm going to change the oil and filter at 500 miles, and the diff oil for the eLSD at 1500. After that, probably oil changes every 5k miles, and the eLSD diff oil maybe once every two years or so. It's a street car and for spirited driving on the weekends once in a while. Basic maintenance will mostly be done at my home on race ramp cribs. Am I missing any other maintenance items I should be proactive on? Also thinking about getting the max length warranty once I figure out my actual mileage usage. How's the reliability of the entire platform and the 1LE trim, is it pretty much bullet proof? Seems like the $1485 for an 8yr/56k/0 deductible quote I got from one of the well known warranty dealers is a bargain. |
08-15-2022, 01:53 PM | #2 | |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
2020 ZL1 A10 Shadow Gray Metallic
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
08-15-2022, 02:08 PM | #3 |
Drives: Chevrolet Corvette Join Date: Jan 2021
I bought mine for the same reason - window of opportunity to own a V8 with manual trans is closing quickly, and I also intend long term ownership. Unless you intend for this to be your daily driver, I would suggest a battery tender. I use them on several of my vehicles and equipment, and have had very good luck with long battery life. Congrats on the car, sounds nice.
08-15-2022, 02:27 PM | #4 |
ive had my car 6 years and almost 35k miles no major issues just oil change brake fluid change rear diff fluid and tranny fluid changes. just did full brakes last month and gone throw tons of tires and upgraded
only warranty issue i had was steering wheel emblem replaced and belt tensioner other than that been pretty rock solid
08-15-2022, 02:44 PM | #5 | |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
You can quote the Magnusson-Moss Act to them until your blue in the face. If they say no, you'll have to get a lawyer to get them to say yes. Doesn't matter if you're 100% right or not. Just food for thought...
08-15-2022, 02:46 PM | #6 |
Drives: 2023/2SS/1LE/RadiantRed/A10 Join Date: Jul 2022
I wouldn’t suggest being so rude to employees and I wouldn’t ask for warranty engine work with a catch-can attached.
2023/2SS/1LE/Radiant-Red/A10/Sunroof/Copper-Free-Breaks/Navigation —— Order History: 6/17/22-1100, 3/7/23-3000, TPW-4/3/23, 4/4/23-3800, 4/8/23-Delivered
08-15-2022, 02:47 PM | #7 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Probably best to avoid the issue then.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
08-15-2022, 03:24 PM | #8 |
Definitely don't want to give the dealership any reason to deny warranty. Most of the basic maintenance will be done at home, but I will probably keep the stock PCV tubes+basic tools to remove the catch can if I have a sudden unexpected need to go to the dealer, i.e. broke down on the side of the road. I did the same for my last vehicle.
Agreed with the Magnusson moss act, they can just give you a reasonable response and it's an uphill battle for you from then on. |
08-15-2022, 03:51 PM | #9 |
Drives: Chevy Camaro Join Date: Apr 2020
There is really nothing special to do to them. Change the fluids when they need to be changed and replace wore out parts before they cause issues and it will last a time. How it is stored will be the biggest factor of how long it will last.
08-15-2022, 03:57 PM | #10 |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
Nothing special. Do the maintenance when it's required, otherwise drive it and enjoy it. It's and auto, not different then any other auto. Take care of it and it will last.
08-15-2022, 04:12 PM | #11 |
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
I'm at 49,900+ in my 1SS, 1LE, as other's have said multiple sets of tires. Still original brakes, nothing done other than standard maintenance. I have no catch can and I agree that having one could potentially cause warranty issues. I might go with the paint protection, but my experience is that modern paint jobs leave a lot to be desired so you're going to get chips no matter what you do. If mine gets to the point where it bothers me I'll pay the bucks to get a nice paint job to replace the factory.
I'm not sure if that extended warranty is a bargain or not. If I had purchased one I would have yet to claim against it and there would only be about 6,000 miles left on it. |
08-15-2022, 04:12 PM | #12 |
Lives in the garage when it's not being driven.
08-15-2022, 04:14 PM | #13 | |
08-15-2022, 04:31 PM | #14 |
