06-03-2022, 08:39 AM | #1 |
Drives: 2019 Camaro 2SS Join Date: Aug 2009
Front Brakes Dealer Quote
I need new front Brembos on 2019 Camaro 2SS. It’s gone 23k miles. Dealer wants $950. Does this sound like a good price?
Thanks. Sent from my iPhone using Tapatalk |
06-03-2022, 08:46 AM | #2 |
17’ Hyper Blue 2SS
Does it sound like a good price? In comparison to d.i.y, hell no!
Does it sound right with the ridiculous cost of labor at a dealership though? Yes. |
06-03-2022, 08:49 AM | #3 |
Drives: 2019 ZL1 A10 Join Date: Aug 2018
1K for pad replacement? Rotors? What's the deal?
06-03-2022, 08:54 AM | #4 |
Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
The exact oem parts (rotors and pads) can be shipped to your door for under $400 bucks. They are up charging you like crazy for the parts. Rotors should be roughly $210 shipped (shipping is expensive on rotors) and pads are roughly $160.00
06-03-2022, 09:03 AM | #5 |
Drives: 2020 LT1 M6 Join Date: Jan 2016
Does not sound like a good price at all.. Buy the parts and find a reputable local shop for a quote. An honest business will only charge you 1 or 1.5 hours of labor.
06-03-2022, 09:15 AM | #6 | |
Drives: CHEVROLET CORVETTE Join Date: Feb 2021
24 Months/Unlimited Mile Warranty** $139.95* ACDelco Silver (ACDelco Advantage) Front Brake Rotors Installed on most cars & small SUVs $199.95* 12 Months/Unlimited Mile Warranty** This is from Estero Bay Chevrolet. They didn't advertise for rear brakes or rotors. Roger Dean Chevy had the same offer within a few $$$$. I would check the website of the dealer who gave you what seems to be a high quote. Hope this helps. |
06-03-2022, 09:18 AM | #7 |
Shadow Gray '19 ZLE M6
It's really an easy install -- Brembos are a breeze to do pads on. With 23k miles on the car, I doubt you need rotors.
To change pads, it's literally pop out 2 pins and retaining clip, use old pads to compress pistons, remove old pads, slide in new pads, re-install retaining clip and 2 pins. Not sure if SS brakes have shims & lube on front and/or rear, but those are simple extra steps. About an hour job to do all four. Where in NJ are you? I may be able to help.
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube Last edited by RamAir02; 06-03-2022 at 09:31 AM. |
06-03-2022, 09:32 AM | #8 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
Like others have said, bad deal. Just get new pads and install them yourself. It's very easy. You need like 4 tools.
Torque wrench for wheel nuts. a 13mm (I believe, could be wrong) for the caliper nut a skinny tool to push the pins out something to push the pins in, could just tap them with a wrench To separate the pads from the rotors you can just use your hands to push the pad out against the pistons. After you're all done just check the brake fluid level and change that too if you'd like. Plenty of youtube videos on this stuff. If you don't feel comfortable then buy the parts yourself and check with a local shop for them to do it. |
06-03-2022, 09:36 AM | #9 |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
As others have said... not no, but hell no...! Brakes really are not difficult. Watch a YouTube Video and do them yourself. Maybe a buddy that knows how? If you have to take it in, I most certainly would call around and get other quotes.
06-03-2022, 10:12 AM | #10 |
Drives: 2SS 1LE Join Date: Oct 2011
What’s wrong with your calipers?
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
06-03-2022, 10:13 AM | #11 |
pads and rotors or?
06-03-2022, 11:34 AM | #12 |
L8ap3x
For god sakes no.
I'm a girl and just took off my rear rotors and pads to clean the rust and imprint off them at 25k. It was an easy job. The hardest part about this job is breaking the caliper bolts loose and that's IF you're doing rotors. If just the pads then the hardest part is getting the tire off. No. Just no. |
06-03-2022, 11:43 AM | #13 | |
Drives: Chevy Camaro 2021 ,rs, v6, manual Join Date: Feb 2022
06-03-2022, 11:46 AM | #14 |
Important to know if rotors are parts of this price ($950). If it is just pads, the price is absurd, even if they turn the old rotors (which they should).
yes, brakes are pretty easy. But I know many guys who fancy themselves handymen or DIY'ers, but don't trust themselves to touch brakes. I get it. I would find out exactly what's included for the dealer price. I would suggest getting a price from a local mechanic. Offer to buy the parts yourself and just pay for labor. This is probably your cheapest option short of full DIY. Plus you can switch to ceramic pads if you don't track the car. |
