Old 05-14-2021, 10:00 PM   #15
Modernmusclecar
Modernmusclecar's Avatar
Drives: 2011 Camaro SS
Originally Posted by Cyber10 View Post
I might be mistaken but when you go 3.91s on an L99 don't you basically lose 1st gear due to how short the gear is?
No thats not true at all. Most of those comments come from people that dont have 391s....they speculate.
EPS CUSTOM GRIND CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBE HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3800 Pro Series stall...391 gears.....Ported/modded GPI intake .Forgestar drag pack with Mickey Thompson ET street drag radials AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
Modernmusclecar is offline   Reply With Quote
Old 05-14-2021, 10:09 PM   #16
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
Not at all, BUT, I'm not cammed or supercharged. Now, if I floor it from a dig, ya, I'm gonna have a hard time...
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 05-15-2021, 08:21 AM   #17
Modernmusclecar
I was fbos for years and with drag radials it wasnt to bad. Now that im camned it skates pretty good. Now it hasnt been sunny and warm yet where i live so i will have to wait to give an honest opinion. I find when i go wot throttle from say a 30 roll it breaks loose. I think it would do that regardless of gear once you up the power. A new set of Nitto 555r2 drag radials are on order tho
Old 05-15-2021, 08:37 AM   #18
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
I spin at any speed below 65. Even with drag radials. It comes with the power. I would say once your over 600whp you are going to start having this issue from my experiences.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 05-15-2021, 11:52 AM   #19
Cyber10
Cyber10's Avatar
Drives: 2010 Camaro 2SS/RS
I always just assumed it was true from how my car drives, first sucks for me even though I'm not geared
491 hp/438 tq
LS3 Conversion | Comp Cam Custom Grind | Mast Heads | Comp Cam Push Rods | LS7 Timing Chain | 180 Thermostat | Ported Intake | Ported TB | SLP UDP | K & N CAI | Custom 3800 Stall Converter | Aluminum 1 Piece Driveshaft | Kooks 1 7/8" LTH | High Flow Cats | ARH 3" Exhaust | ARH Mufflers | Eibach Lowering Springs | BMR Floor Brace Subframe Connectors with Tunnel Brace | BMR Moly Lower Rear Control Arms | Oracle LED Halo Kit
Cyber10 is offline   Reply With Quote
Old 05-15-2021, 07:59 PM   #20
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
For me also 1st is just a waste of time with even the stock gear I'm still running, I will start off in 2nd manual mode for any digs and it will still lightem up and shift accordingly. In sport I have to feather it off the line then romp on it and she still spins, but hooks quicker once it shifts to 3rd.
1JEWLDSSRS is offline   Reply With Quote
Old 05-15-2021, 09:26 PM   #21
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
You make it to the track with your latest setup Wayne?
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 05-16-2021, 06:49 AM   #22
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Hey Chris, no sir haven't made it over yet. Had too many "life" things going on and with the COVID lifestyle it made it kinda tough to get there, and as always when I'm ready to go, the Florida weather in Orlando doesn't play nice, been kinda tough on the car show scene here too, but I'm optimistic though I will make it over before summer and the sweltering heat!! lol.
