03-08-2020, 06:25 PM | #15 | |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Are you fans even kicking on? It could be an air pocket, but usually they work themselves out. Are you having to top off your coolant quite often? Are both the upper and lower radiator hoses hot? Maybe a stuck thermostat. No matter what T-stat is used it shouldnt get that hot. What does your oil look like? I honestly wouldn't drive it until you figure it out.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come. |
03-08-2020, 06:44 PM | #16 | |
Drives: 2010 Chevrolet Camaro SS Join Date: Sep 2019
Thinking I need a better Tstat for sure... My coolant is doing well enough, I'll go out and buy another gallon since I ran out of the last one. I can hear the fans working hard when I shut off the car.
2010 Camaro 2SS/RS:
Cyber gray matte wrap, Danti Lambo style louvers, Granatelli Pro-stock look wing B&M transcooler, Mishimoto oil cooler, Mishimoto catchcan, Borla/Pypebomb axle back L99 to LS3 conversion, Vararam ram air intake, BTR Nightfury cam, Johnson lifters, LS7 injectors, Circle D 3200 stall converter, Kooks LT headers, Custom X-pipe |
03-08-2020, 08:26 PM | #17 | |
SomeguyK
More to come. |
03-08-2020, 08:57 PM | #18 |
Drives: 2012 SS Join Date: Feb 2016
Call me crazy, but I run a 180 stat with lowered fan settings. Works great. When moving runs at a solid 183. In traffic runs the mid 190s. Didn't want to go too cold.
2012 2SS/RS 6speed, Howards asa cam on 113lsa Stainless works LT's, NPP exhaust, Z28 Cai, 3.91 gears. Tuned by Blue Thunder 2 racing Lubbock Texas.
03-08-2020, 09:02 PM | #19 |
SomeguyK
That's not crazy. I don't see below 190 or above 200 with a 160 stat and my fan settings.
More to come. |
03-08-2020, 11:26 PM | #20 | |
And no, I have coolant in the thing now, the oil is fine and so are all the other fluids. I think I just need a better Tstat for the car since I'm running this sort of setup, everything is fine at highway speed. But then my next question is why is my foot getting so hot when the car is on?
2010 Camaro 2SS/RS:
03-09-2020, 05:10 AM | #21 | |
SomeguyK
What do you mean your foot is getting hot? Do you have the air on?
More to come. |
03-09-2020, 10:18 AM | #22 | |
2010 Camaro 2SS/RS:
03-09-2020, 10:54 AM | #23 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Ok rifling through this, Teeth it sounds like your fan's are not working at all. That is a problem you must have your fans operational for slow speeds and stopped driving, get that fixed asap. A Tstat won't help any of that if your fans are not working. a 160 degree seems kinda pointless, I have one and the cooling system doesn't have the ability to keep it that cool, I run about 180, so 180 Tstat would be fine. As far as your foot getting hot, how hot are we talking? You are now running headers and if they aren't ceramic coated headers run HOT and can actually glow under WOT and that could be what you are feeling especially if you removed and heat shielding.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
03-09-2020, 03:40 PM | #24 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Why is it so hard to get a simple answer? I think it has been asked many times what kind of coolant temps are you getting when you say 'higher'?
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
03-09-2020, 08:56 PM | #25 | |
Started#gottalovethatblue
I wouldn't go so far as to say with air it sludges either, but I definitely agree with the "Green" and DexCool playing well together. The radiator shop I went to saw the issue regularly and heavily advised that if converting to be sure that ALL of the DexCool was out before converting to "Green". I was wondering the same thing as to specific numbers of "higher". 200*F is higher than normal, but still in standard operating temps. However, 200*F on a 160*F thermostat is reason for concern.
03-09-2020, 09:14 PM | #26 | |
240F
2010 Camaro 2SS/RS:
03-09-2020, 10:04 PM | #27 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
240 is pretty darn hot for casual driving, even in traffic. I think you need to do some basic troubleshooting before you cook your engine. All air out of system. Fans coming on and spinning in correct direction, note temp they come on. Fans coming on with AC selected. Good airflow through radiator. T-stat opening. Ignition timing correct. I've had to do some pretty hillbilly tricks on other vehicle types trying to figure hot issues including driving with no hood and 12v direct to fans for temporary full time operation. I wouldn't drive your Camaro for transpo until problem is fixed and I would definitely not run the AC. Get a rental or something. You live in AZ, you need to fix this soon before the weather gets toasty.
03-09-2020, 10:46 PM | #28 | |
Drives: ABM #93 Join Date: Oct 2018
How do you hear the fans working hard but they’re not coming on at all? Most of this thread doesn’t make any sense...
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
