03-07-2020, 07:59 PM | #1 |
Drives: 2010 Chevrolet Camaro SS Join Date: Sep 2019
Did a coolant flush, added "green stuff", forgot to top off reservoir
Should I just dump more "green stuff" in there too?
2010 Camaro 2SS/RS:
Cyber gray matte wrap, Danti Lambo style louvers, Granatelli Pro-stock look wing B&M transcooler, Mishimoto oil cooler, Mishimoto catchcan, Borla/Pypebomb axle back L99 to LS3 conversion, Vararam ram air intake, BTR Nightfury cam, Johnson lifters, LS7 injectors, Circle D 3200 stall converter, Kooks LT headers, Custom X-pipe |
03-07-2020, 08:40 PM | #2 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
As long as you flushed out all of the Dexcool, you can use the green stuff. The two shouldn't be mixed.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come. |
03-07-2020, 08:51 PM | #3 |
I'll probably do another flush tomorrow just to make sure, don't know if I can attribute the heat to insufficient coolant or some other thing.
2010 Camaro 2SS/RS:
03-07-2020, 08:58 PM | #4 |
SomeguyK
Heat? What's the problem?
More to come. |
03-07-2020, 09:29 PM | #5 |
Just some excessive heat. I did put in my Nightfury not too long ago, slapped on a B&M for the trans, then noticed oil was going up so I put on a Mishimoto. Still had heat problems...might be because of air flow to radiator with those both in the front now...but when I added the coolant to the reservoir, it began to regulate itself much better.
2010 Camaro 2SS/RS:
03-07-2020, 09:34 PM | #6 | |
SomeguyK
More to come. |
03-07-2020, 09:57 PM | #7 | |
This car can be a PITA sometimes to get all the trapped air of the system. It will act fine like you got it all, then you take a ride and hit 230º. You really need to let it sit idle for a while with the cap off and keep topping off when it drops a bit. As you can see, I just learned how to make a degree symbol in Windows lol (ALT+167). So I am going to be dropping ºººººººººººººººº's all over the place! Yes, I its obnoxious as hell, but I will get over it soon.
03-08-2020, 06:54 AM | #8 |
When changing the coolant is it better to go green?
2013 Camaro SS/RS, Stainless Power long tube headers with HF's, Air Raid CAI, Solo Mach XL cat back, BC Racing coil overs, Elite Engineering catch can, Ferrada Forge 8 Wheels, Windows tinted at 20%, Tuned by Dyno Steve.
03-08-2020, 08:09 AM | #9 |
Drives: 2018 1SS M6 Join Date: Nov 2014
The basic reasoning behind Dex-Cool is that it is a phosphate and silica based chemical, rather than ethelyne glycol, like the green stuff.
Dex-cool is used because it inhibits corrosion in aluminum engines and engines with aluminum parts. The green stuff will change color in an iron block but will not change color in an aluminum engine, when it starts to corrode. The downside to Dex-Cool is that it will sludge when exposed to air, and of course, if combined with the green stuff. Dex-Cool got a bad rap in the late 1990's and early 2000's when it was discovered, or blamed for intake gasket failures on certain V6 engines that had coolant flowing through the intake. Is better to go green? I would say no, not really. The Dex-Cool is purposed for aluminum engines, engines that are designed to run hotter than the old school iron blocks. The system in the aluminum engine is a high pressure system, which also inhibits the coolant from reaching the boiling point. Also, given what can happen if you switch to the ethylene Glycol coolant with out completely, totally, and absolutely flushing the engine of the Dex-Cool and any residual silicates, I would say staying cool with Dex is the way to go. If temps in the engine are hotter than normal, it's because there is an issue in the system. Changing the coolant is not going to fix that. But that's just how I look at it. |
03-08-2020, 08:16 AM | #10 |
SomeguyK
Not necessarily. Dexcool is just fine.
More to come. |
03-08-2020, 08:17 AM | #11 | |
SomeguyK
More to come. |
03-08-2020, 11:01 AM | #12 | ||
Dex-Cool sludge is caused by oxidation A faulty radiator cap, coolant additives and stop leak products, mixing a different coolant into Dex-Cool, running low on coolant or using Dex-Cool in an engine not approved for its use can all cause oxidation and corrosion that forms as a sludge. To avoid sludge, you must keep the system full so air doesn’t enter. The radiator cap must work properly. https://ricksfreeautorepairadvice.co...x-cool-sludge/ |
03-08-2020, 11:28 AM | #13 |
SomeguyK
Oxidation and corrosion can happen to any system using any coolant...not just dexcool. It isn't dexcools fault if someone doesn't maintian their cooling system or fix problems. I've seen sludge in all types of sytems due to lack of maintenance. A cooling system is always exposed to air via the overflow tank. Dexcool is exposed to air in shipping containers and it doesn't sludge.
More to come. |
03-08-2020, 06:19 PM | #14 |
To answer, since I got distracted last night.
It is running on the stock thermostat, and it was suggested that I do get the 160 degreethat, which I'll probably get here soon enough. The car can barely stay in idle traffic for a minute or two without sending my coolant, oil and trans gauges up in temp, which is really bothering me since I do have auxiliary coolers just for the oil and trans. I'll do some more looking into it, I'm just really worried about the car. It gets really bad when I come off of highway speeds and into any normal street...
2010 Camaro 2SS/RS:
