Old 02-05-2020, 12:29 AM   #1
Teeth
Teeth's Avatar
Drives: 2010 Chevrolet Camaro SS
HP/Torque guesses? (current build)
I'm betting 480 wheel and 420 torque on pump gas
Nightfury cam+LS3 conversion
Johnson lifters, new pushrods and springs
Flexfuel kit
Vararam ram air intake
LS7 injectors
3200 stall
Kooks 7/8 headers w/ straightipipe and custom x-pipe
2010 Camaro 2SS/RS:
Cyber gray matte wrap, Danti Lambo style louvers, Granatelli Pro-stock look wing
B&M transcooler, Mishimoto oil cooler, Mishimoto catchcan, Borla/Pypebomb axle back
L99 to LS3 conversion, Vararam ram air intake, BTR Nightfury cam, Johnson lifters, LS7 injectors, Circle D 3200 stall converter, Kooks LT headers, Custom X-pipe
Teeth is offline   Reply With Quote
Old 02-05-2020, 05:16 AM   #2
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
Maybe on a dynojet. That's a high number for an auto without any headwork. Depending on which mustang dyno I use. I put down between 460 and 470 hp @ 6600rpm on E85. Which would be in the low 520 ish hp on a dynojet.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come.
Black_SS10 is offline   Reply With Quote
Old 02-05-2020, 01:49 PM   #3
SSkat
SSkat's Avatar
Drives: 2010 Camaro 2SS
Im gonna say 460
SSkat is offline   Reply With Quote
Old 02-05-2020, 11:50 PM   #4
Athletics101
Athletics101's Avatar
Drives: 5th Gen L99
Maybe with heads and on E. I made 466/419 cam heads no E.
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
Athletics101 is offline   Reply With Quote
Old 02-06-2020, 06:49 PM   #5
Avenging Orange
Avenging Orange's Avatar
Drives: 2010 Inferno Orange 2SS/RS
Hmmmm....Im gonna say....whatever the dyno says.
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!!
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
KICKING CANCERS ASS SINCE 2015!!
Avenging Orange is offline   Reply With Quote
Old 02-06-2020, 07:31 PM   #6
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
Underdrive pulley? Ported/rod modded intake manifold?
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 02-06-2020, 10:23 PM   #7
Teeth
Teeth's Avatar
That's pretty good being NA
Originally Posted by SSkat View Post
Im gonna say 460
I hope I can make it up that far on an auto, lol
I even took my heads in to a shop for cleaning/inspection...I really should have had them improved at the same time lol
hahahahahahaha
None of that fancy stuff, sadly
2010 Camaro 2SS/RS:
Old 02-07-2020, 01:43 AM   #8
GAD
GAD's Avatar
Drives: Silver 2014 Camaro 2SS
That’s very very similar to what I have. I came in at 465.xx rwhp on E. I forget the torque, it was way lower than I expected.
2014 Silver 2SS L99 with Roto-Fab CAI, Kooks LT Headers, Kooks Cat-less 3” exhaust, TS Stage 3.2 VVT CAM, Circle D 3200 Stall, E85 Kit, FIC 850cc injectors and Elite Engineering Catch Can. Dynoed at 478rwhp.
GAD is offline   Reply With Quote
Old 02-07-2020, 10:38 AM   #9
Sxren_Camaro'13
SEAHAWKS FOR LIFE!!
Sxren_Camaro'13's Avatar
Drives: '13 Mod Camaro LS
Flexfuel kit
LS7 injectors
3200 stall
460
Sxren_Camaro'13 is offline   Reply With Quote
