12-29-2019, 07:44 PM | #57 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Indeed. Lol
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come. |
12-29-2019, 07:46 PM | #58 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
I remember when I was in your place. Guys on the forum said you will spend alot of money to get from 480 to break 500.... they were right
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
12-29-2019, 07:47 PM | #59 |
SomeguyK
You gotta pay to play.
More to come. |
12-29-2019, 07:53 PM | #60 | ||
Drives: 2010 Chevrolet Camaro SS Join Date: Sep 2019
Seems 450 is a more attainable number tbh, I'll shoot for that on a dyno, I'll be able to run a good amount of cars with that number anyways.
2010 Camaro 2SS/RS:
Cyber gray matte wrap, Danti Lambo style louvers, Granatelli Pro-stock look wing B&M transcooler, Mishimoto oil cooler, Mishimoto catchcan, Borla/Pypebomb axle back L99 to LS3 conversion, Vararam ram air intake, BTR Nightfury cam, Johnson lifters, LS7 injectors, Circle D 3200 stall converter, Kooks LT headers, Custom X-pipe |
12-29-2019, 07:55 PM | #61 |
Drives: 2010 SS L99 Join Date: Sep 2018
Honestly, if I were the OP I would probably be PMing you and basically copying your build. I took a lot of notes from Pro Stock John on his build and then went on my merry way. And yes, you gotta pay to play. I've dumped plenty of $$$$ into this thing and its FAR from done.
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
12-29-2019, 08:32 PM | #62 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
It's not all about power. Gearing and torque converter, tuning are key. There's guys with a lot less power than me that would give me a run for my money or beat me at the track with autos.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
12-29-2019, 08:39 PM | #63 | |
SomeguyK
More to come. |
12-29-2019, 09:11 PM | #64 |
Drives: 5th Gen L99 Join Date: Nov 2017
OP just needs to do a lot of research. We have all been there.
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
12-30-2019, 07:06 AM | #65 |
Started#gottalovethatblue
That is a much more realistic and obtainable number for an automatic car. Besides you'll beat manual 500rwhp cars with 450rwhp in an automatic especially if you have the appropriate converter paired with your application.
12-30-2019, 06:13 PM | #66 |
Drives: 2014 2SS/RS Join Date: Jan 2018
He speaks the truth. The autos shift so much better than the best manual driver.
2014 2SS/RS LS3/M6
12-30-2019, 07:14 PM | #67 | |
Drives: Camaro Join Date: Oct 2018
12-31-2019, 12:51 AM | #68 |
For me, I have in it what I paid for it initially.
