12-26-2019, 03:42 PM | #29 | |
Drives: 2015 Camaro 2SS RS 1LE AGM Join Date: Oct 2013
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
12-26-2019, 04:46 PM | #30 |
weSS1LEy
Drives: 2015 camaro 2ss/rs/1le Join Date: Sep 2015
It sounds like what is needed for 500whp Na will interfere with sc later. Btw does anyone else feel night fury intake duration is pushing it a bit?
Rotofab, arh no cats, atak, elite cc, 94 octane tune, Mobil 1, phastek scoop, custom cam 230/243 .621 .604 114+4, related cam kit stuff. 470/435 rwhp/rwtq
12-26-2019, 09:44 PM | #31 | |||
Drives: 2010 Chevrolet Camaro SS Join Date: Sep 2019
Also what would the intake duration have an impact on? |
12-26-2019, 09:54 PM | #32 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Intake duration affects valve overlap, something you don't want too much of on a PD supercharger setup, you just blow the boost out the exhaust.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
12-26-2019, 09:56 PM | #33 |
12-26-2019, 11:04 PM | #34 |
Drives: 2014 2SS/RS Join Date: Jan 2018
With the amount of money it takes to get the L99 to this point, you might be better off just throwing boost on it.
2014 2SS/RS LS3/M6
12-27-2019, 04:51 AM | #35 | |
Drives: '23 LT1 A10 Join Date: Oct 2015
24 LT1 M6 Sharkskin Metallic
12-27-2019, 05:49 AM | #36 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
It works just fine for daily. The power band is in the higher rpm range then the factory piece. If your goal is 500hp you'll need a mid rise or high rise intake.... like the LOD.
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. Last edited by Clarkstar; 12-27-2019 at 08:41 AM. |
12-27-2019, 06:40 AM | #37 |
Started#gottalovethatblue
The same principles apply for turbos. If your intake and exhaust valves are open at the same time you will not be able to build boost in your cylinders which will rob you of power. That's the same for all boosted applications whether positive displacement supercharger, centrifugal supercharger, or turbo(s).
12-27-2019, 07:32 AM | #38 |
Turbo requires even less duration than a sc to be effective. It's not that it won't work. Any cam will work it's just you won't get as much boost out of it, fou have to spin the turbo, sc whatever faster to get the same boost level if the cam is too big. So, to me, building badass fast NA car doesn't always play well if you plan to boost it later. No matter what if you stick boost on something you are still going to gain power it just may not be as much power as if you were building for boost to begin with. Lots of guys swear by running stock cam profiles with turbo cars especially since at lower rpm you are not building much boost so when there's a bunch of overlap that boost is even harder to achieve. I've done a lot of research and read a lot of different things. I'm not an expert, i'm just going by what i took from my research so take my advice with a grain of salt. I've always stuck with the general rule of thumb, on boosted applications i want 10 degrees less intake duration than exhaust and .20 less intake lift than exhaust. If you are going big on a can lobe separation of more than 114. But there's a lot in play. If you have a smaller profile cam on a turbo you can run a tighter lsa. There's so much research and so much in play it's not an easy answer. I'd suggest if you really are planning on boosting it to just buy a cam profiled for what you want to boost it with right away. I ended up buying jannettys rough idle sc cam. He recently posted a dyno run with his smooth idle sc cam on a turbo car and it made like 760whp i think.
12-27-2019, 02:04 PM | #39 |
No lack of torque in the lower rpm range?
12-27-2019, 02:06 PM | #40 |
Remember with a bigger cam and higher stall converter, you'll be in the lower rpm range less anyway
2014 2SS/RS LS3/M6
12-27-2019, 02:07 PM | #41 |
My dyno numbers showed a loss of torque... buy I can't really feel it. Pulls like a raped ape!
603 h.p. 495 ft lbs tq. |
12-27-2019, 02:19 PM | #42 |
Drives: 2010 SS L99 Join Date: Sep 2018
+1.
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
