06-21-2018, 08:12 AM | #1 |
Drives: 2014 2SS/RS 1LE Camaro&16 Silverado Join Date: Aug 2013
2017 ZL1 six piston calipers fit on my 2014 SS/1LE?
So I have an opportunity to buy a set of front calipers off a 2017 Zl1 and I want to do a brake upgrade on my 2014 1LE. Does anyone know for sure if the zl1 calipers would bolt up? Obviously I'll need new rotors and pads.
Sent from my SM-N950U using Tapatalk
Z28 Brake ducts, CAI & Tune
"Never let fear decide your fate!" |
06-21-2018, 08:23 AM | #2 |
Drives: 2015 2ss Join Date: Jun 2009
subb'd, i'm interested to know as well.
2015 Camaro 2ss, NicKey Performance built/tuned |
06-21-2018, 11:22 AM | #3 |
Drives: 2004 GTO & 2005 GTO Join Date: Mar 2014
No, they will not bolt onto a 5th Gen. You need to get 5th Gen ZL1's.
06-21-2018, 02:15 PM | #4 |
My understanding is that they will fit but the rotors are a different offset.
Orange Krush II
06-21-2018, 03:23 PM | #5 |
5th gen ZL1's will fit with different rotors. 6th gen ZL1's will not fit on a 5th gen.
07-26-2018, 11:33 PM | #6 |
Drives: black Join Date: Mar 2017
Camaro 6 guys said the 1LE caliper is the same as the c7 Z06 caliper. The C7 Z06 caliper goes on the camaro 5 no problem
Rotors are completely different offset. The two piece rings interchange. But you need a camaro 5 ZL1 rotor or at least the hat to put the rings on. |
07-27-2018, 08:44 PM | #7 |
Yes they will work but think the ZL1/1LE are more akin to the Z28 calipers.
Orange Krush II
01-28-2023, 01:30 AM | #8 |
Drives: 2010ss M6 LS3 Join Date: Jun 2018
Hey guys, I know this is an old thread, but Reichler posted twice that gen6 2017+ ZL1 front caliper WONT fit a gen 5 camaro. I believe this is incorrect/wrong. Can you guys confirm?
I know that you have to change pads, hoses, and rotors (unsure which rotor to use to fit 2017 ZL1 front calipers onto a gen5 SS?). THanks
2010 SS M6, stage 2 summit cam, CAI Intake/long tube cat delete with flow master/ZEX NOS at 150RWHP/ custom tune/MSD wires/short throw shifter/ crank vent catchcan/ SS braided brake lines/ 1.5” lower springs/bigger rear sway bar/fully poly bushings everywhere/toe arms/trail arms/front caster plates/factory shocks/steering poly inserts
01-28-2023, 05:35 AM | #9 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
I have Gen6 ZL1 calipers and rotors on my turbo car. They are essentially the same as Z28 calipers. The hats on Gen6 ZL1 rotors have a different offset, like by 10mm, so you have to solve that problem. I used hats from ZR1 carbon brakes with a bolt kit from KNS but the ZR1 hats are 2mm smaller than the Gen6 ZL1 hats and they are often hard to find. If you really want the 390mm brakes, use the Gen6 ZL1 caliper with GiroDisc Gen5 Z28 iron conversion rotors. They are a bit pricey around $1400, but the factory rotors are over $400 new and you will have a better setup. Use pads for a Gen6 ZL1 caliper; street pads are readily available on RockAuto. Obviously, track pads are available from numerous vendors.
The rears on a Gen6 ZL1 are the same as Gen5 SS/ZL1 calipers. They bolted right up and used the rotor I already had on the car.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
01-29-2023, 09:04 AM | #10 | |
Now thats GREAT info right there!! Thanks, and a thank you for future guys searching aswell 👍👍
