Old 05-07-2018, 03:05 PM   #15
Nitro66215
Nitro66215's Avatar
Drives: 2017 ZL1 Vert - M6,SIM,CFW,NAV
Originally Posted by mbnwa View Post
I just ordered all the parts guess we will find out shortly I know they offered it on the Vert Corvette, as I owned one in the past. Any additional info anyone finds out would be great and I will post back any of my updates after all my parts come in. I did get the PDR out of a CTS-V so fingers crossed it should be the same one it's a different part number vs what was listed above.
Doing this on a vert?
2018 2SS Vert - Hot Wheels - Indy 500 #30
2017 ZL1 Vert - M6 , SIM, CFW, NAV
2017 RS 1LT 2.0T Vert - A8, Garnet Red - SOLD :-(
Added - IO6 - NAV, UHS - Enhanced Display, K4C - Wireless Charger, UV6 -
Heads-Up Display - DIY
2011 CTS-V - Black / Black - SOLD. :-(
2013 ZL1 - Black / Black - SOLD. :-(
2010 2SS - Indy 500 Pace Car. - SOLD. :-(
2002 Z28 - Pewter / Black - SOLD. :-(
Nitro66215 is offline   Reply With Quote
Old 05-07-2018, 03:16 PM   #16
mbnwa
Drives: 18 NGM ZL1 1LE
I am 17 2SS vert.
I am waiting on my HMI with the PDR software, the Camera / PDR from a CTS-V was just sent out today, I ordered the SD card reader and the camera mount from gm parts direct.
Camera PN 23404614 - wrecked CTS-V
PDR PN 84105487 - wrecked CTS-V
Camera Bracket PN 84169133 - GM Parts Direct
Camera Cover Bracket PN 84283507 - GM Parts Direct
SD Card Holder PN 13599465 - GM Parts Direct
PDR GPS Antenna PN 23480909 - GM Parts Direct
mbnwa is offline   Reply With Quote
Old 05-07-2018, 03:17 PM   #17
Nitro66215
Nitro66215's Avatar
Here's the end connector wiring...
Old 05-07-2018, 03:20 PM   #18
mbnwa
Thanks
Old 05-07-2018, 03:31 PM   #19
mbnwa
Can anyone with a PDR share a pic of where the camera lines up at on the back of the mirror? I highly doubt that the camera bracket will work on the vert and fully expect to be required to build a custom mount enclosure for it.
Maybe a picture from the front of the windshield and a side shot showing along the rear view mirror would be helpful.
Thanks
Old 05-07-2018, 06:37 PM   #20
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
it uses little tabs that glue to the windshield similar to the way a mirror connects to glass windshields.
Im going to make some later this week and just buy some rear view mirror glue to glue them on.
2018 MBM ZL1 1LE - Stock
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 05-07-2018, 07:30 PM   #21
mbnwa
So I got my HMI today, however I am not sure that they loaded the PDR software as I do not have the PDR icon, however with my HMI the green USB plug was not connected to anything, (/start of assumption) I am thinking that the green plug goes to the HMI from the PDR I assume this is how the touch commands are sent to the PDR
From the looks of the diagram / camera setup I assume the black USB plug goes to the camera
That would leave the blue plug for the SD Card reader.
As far as the two plugs on the other side of the PDR I have no idea where they go at this point in time.
/end of assumption
I need to call the guys who did the PDR software load tomorrow and find out what's up since I have all my parts on the way.
Old 05-07-2018, 07:36 PM   #22
nighttowl
nighttowl's Avatar
Not having any luck on these connectors.
I may have to fire up the 3D printer...
Old 05-07-2018, 07:39 PM   #23
mbnwa
On the USB or the other two? for the USB connectors I picked up 3 USB extension cables from Amazon, the other two connections I figure I will deal with when the PDR and everything get's to my door and I can get a good look them.
I might try to hit up a wrecking yard and see if I can follow the connections back and see how everything connects.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I just realized that the HMI to PDR will require a male to male connector so I just ordered
https://www.amazon.com/CablesOnline-...n+Male+to+male
Old 05-07-2018, 07:49 PM   #24
nighttowl
nighttowl's Avatar
I was searching for connectors with locks on them similar to factory. possibly someone near me is salvaging a newer car i can get wiring from.
Old 05-07-2018, 07:51 PM   #25
mbnwa
I figured this would work to mock everything up and make sure everything works, after I can confirm that everything is good I will look for the factory cables.
I agree I would like to keep it as factory as I can however until I can get some part numbers for the cables I'm a but limited on options.
If you do happen to get wiring from a salvage feel free to post the PN's for the cables
Old 05-08-2018, 10:45 PM   #26
nighttowl
nighttowl's Avatar
i found several usb data cables
https://www.amazon.com/s/ref=nb_sb_n...+cable+acdelco
Old 05-09-2018, 12:50 PM   #27
Nitro66215
Nitro66215's Avatar
/end of assumption
The Service manual only shows HMI X1,2,3,5, 7 being used
Old 05-09-2018, 12:57 PM   #28
mbnwa
hm yeah I am trying to get all the diagrams together, like I said in my post it's strictly an assumption until I can find more details. however based on the PDR diagram I posted X3 on the PDR goes to the Info Display module (I assume X3 is USB) X5 is SD card (USB) X4 is the camera is USB X6 is the antenna X1 and X2 seem to be the larger data plugs.
