07-28-2015, 10:53 PM | #1 |
Drives: 2015 Camaro 1LE Join Date: Jul 2010
Factory put on wrong tire
I bought my 2015 1LE brand new back in January. Today I finally made it to 1500 miles and took a good look at my tires to see how they were. I was surprised to see that I have a 305/35/20 in the rear and the other 3 tires are 285/35/20. This is how it came from the factory, the car had 6 miles on it when i bought it. I guess somehow the factory screwed up and put a ZL1 tire in the rear. Hard to believe this would happen, go figure.
I'll be visiting my dealer of Friday to see what they will do. |
07-28-2015, 11:00 PM | #2 |
Drives: 2010 r/s switchblade metalic Join Date: Oct 2011
They screw up all the time. We bought a new Camaro in 1988, and rode around about a month before we realized that we had one grey door handle/armrest and one black! Of course they changed it out for us.
07-28-2015, 11:19 PM | #3 |
Drives: Love the one you're with Join Date: Sep 2009
I've heard of worse happening. They should correct that. I only worry would be them screwing up the wheel when they change the tire to the correct size.
You know on second thought the wheel size is probably wrong too. It is most likely an 11" wheel. |
07-29-2015, 12:42 AM | #4 | |
Drives: 2015 Camaro SS/1LE Join Date: May 2015
10 inches in front and 11 inches in rear; same as ZL1. But with 285 tires on all 4 corners.
2015 2SS/1LE/RECARO/NPP/RS/NAV
07-29-2015, 12:44 AM | #5 |
Drives: 2010 Camaro 2SS/RS Join Date: Oct 2013
wow
07-29-2015, 04:35 AM | #6 |
Hopefully they can match the 305 on the other rear wheel, they look so much better than the 285.
07-29-2015, 06:10 AM | #7 |
10/4, I never looked it up. I thought the 1LE had 10's all around because of the tire size. Doesn't make much sense to me to have 11's on the back with the same size tires as the front. Wonder what the advantage is to that combination.
07-29-2015, 06:29 AM | #8 |
ultracrepidarianism
Drives: '14 1SS/RS/1LE/NPP '18 Accord Sport Join Date: Mar 2014
might have been more of the oshawa swan song snafu. might have been damaged in transit or at the dealer and replaced by the seller. can't believe you never noticed. they don't look similar even at a glance.
07-29-2015, 06:31 AM | #9 |
ultracrepidarianism
square set up for plow reduction. maximizes 1lE balance and handling.
07-29-2015, 06:34 AM | #10 |
He will want to get a 285 back on that rim not another 305. On the 1LE if you have staggered tires you are going to get understeer.
When I put my 1LE suspension on I originally had my staggered factory wheels, understeer was horrible compared to stock. When I get my Factory Reproductions and went all same size tires the car rocked. |
07-29-2015, 08:36 AM | #11 |
Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
Get the 285, but as others have said, how did you not notice? Thats a pretty big difference.
07-29-2015, 11:02 AM | #12 |
Drives: 2013 2SS/RS/1LE Join Date: Apr 2010
It's been reported here before.
07-29-2015, 12:42 PM | #13 |
Im actually surprised that I didn't notice this before. I dont drive it much and it just sits in the garage, so maybe thats why. Lets see what the dealer does.
07-29-2015, 12:55 PM | #14 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Very odd you didn't notice it sooner. I check my tire pressure every week and inspect the tires.
OLD GUY FLYING FAST AND LOW
Thread Tools | |
