02-15-2021, 12:30 PM | #1 |
Drives: '17 2LT/RS 2.0T M6 50th Anniv Vert Join Date: Feb 2019
Fender Liner
I purchased Diode Dynamics smoked side markers and of course went to YouTube to learn how to do the install. In all the videos I've seen, the front fender liner has an opening near the location of the side marker.
On my car, 2LT/RS 2.0T, that opening is covered. Wondering if there is a reason (ZL1, SS only, heavy duty brakes, etc) that mine is closed off. Looking for any input on this. Thanks in advance... |
02-15-2021, 12:48 PM | #2 |
Drives: 23 ZL1 6speed Join Date: Aug 2020
Open the portion of the fender liner up (by removing screws, etc.)? It should be fairly straightforward once you start tinkering.
02-15-2021, 01:07 PM | #3 |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
02-15-2021, 08:38 PM | #4 |
Thanks guys! I'm less concerned with the install (definitely look straightforward), more concerned if I need to remove or cut-out that cover.
02-16-2021, 09:07 AM | #5 |
Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
Na, you can pull back the liner enough to reach behind and pop those little clips no problem.
