09-20-2020, 03:30 PM | #1 |
Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10 Join Date: Dec 2017
Front brake bolt spec quick one...
Guys, anyone know the exact size of the nut on the front brake for the ZL1 (the one that needs to come off for brake pads install)? Don’t want to take my wheel off to figure it out if possible
09-20-2020, 04:00 PM | #2 |
Did some heavy duty search : it’s 13mm
09-20-2020, 04:04 PM | #3 |
Drives: '19 ZLE, S54 E36M3 Join Date: Feb 2018
I’d like a source for the bolt and nut... All I’ve found so far is a complete caliper.
09-20-2020, 04:39 PM | #4 |
Is that a TTY too? I did not think so....
09-20-2020, 07:52 PM | #5 | |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
https://wildhammermotorsports.com I don't believe so either. FWIW the torque for the caliper bridge pin bolt is 22 lb-ft
09-20-2020, 08:07 PM | #6 |
Thank you
09-20-2020, 08:18 PM | #7 |
