09-19-2019, 05:39 PM | #1 |
Drives: 2022 ZL1(FEA suspension) Rapid Blue Join Date: Apr 2019
"Winter Storage"
For you blokes that put your babies in storage during the winter months. Curious if anyone has had issues with flat spotting tires?
I was also thinking of jacking the car up, but then thought that extending the dampers to their furthest position for an extended time could be detrimental. Am I over thinking this whole thing? |
09-19-2019, 05:48 PM | #2 |
Retired from Car mfrs....
Yes you are, normal winter storage wont flat spot modern tires.
09-19-2019, 06:15 PM | #3 |
Agreed. I have two 'Garage Queens', that I store covered in my garage on their plain old rubber. Never had an issue with flat spots. BTW I put them both into hibernation on Halloween and wake them up around May 01. No issues yet...
09-19-2019, 06:23 PM | #4 |
Drives: 2017 ZL1 Convertible A10 Join Date: Aug 2017
Southern California
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq) '17 Maserati Levante- STOCK |
09-19-2019, 06:31 PM | #5 |
Drives: 2018 ZL-1 Join Date: Jan 2018
My stock tires flat spotted last winter. I burned them up at the dragstrip in the spring, then got a set of Michelins and some tire cradles. There are clearly different viewpoints regarding tire cradles.
09-19-2019, 07:18 PM | #6 |
Drives: 18 Tahoe RST, 19 Z06 Join Date: Apr 2017
Mine was stored for 7 months last winter with no flat spotting.
09-19-2019, 07:39 PM | #7 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
Yeah weird. I’ve stored lots of different vehicles over the years . I usually find they flat spot. Quick couple mile drive and the flat spot is gone. My worst was my Suburban. Michelin LTX tires. They were great but if I didn’t drive it for say a month or 2 they would flat spot. All my others that were left on the ground flat spotted but nothing ever permanent.
09-19-2019, 08:37 PM | #8 | |
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
09-19-2019, 08:47 PM | #9 |
2018 Garnet Red ZL1 conve
Drives: 2013 & 2018 ZL1 vert Join Date: May 2009
What I do is use two each of the 4 pc. Anti-Fatigue Foam Floor Mats from Harbor Freight and drive the car up over and on top of these pads, two under each tire. Works like a champ along with the battery tender for long term storage!
Build Thread: 2018 ZL1 Vert Purchased (Overpar73)
09-19-2019, 09:45 PM | #10 |
Greatly appreciate the feedback guys. My garage floor has 'corrocated' tiles. I'll use mats to smooth the surface and see what the results are.
09-20-2019, 01:10 AM | #11 |
Drives: Really Fast Join Date: Aug 2017
Going on the third winter now. I fill the gas tank, park it in the garage and throw the cover on it. Spring time no issues! Tires are still round. Battery doesn’t even need a tender. Starts right up.
THIS SPACE FOR RENT
09-20-2019, 05:54 AM | #12 |
Drives: 2016 Camaro 2SS Join Date: Sep 2015
I have stored my car past 3 winters...no flat spotting...i did increase the air pressure in tires to 44-45psi before it went in to storage...
2016 Black 2SS A8 NPP Sunroof - Tinted Windows - Black Chrome Wheels - Custom Striping - ASC Sideskirts/Splitter - GM Lowering Kit - Complete Sound System - DD LED Sidemarkers
09-20-2019, 07:11 AM | #13 | |
Overfill the tires to 50 lbs or so. I use carpet squares under the tires to separate from the cement garage floor. Tires will not flatspot. Use a good battery tender. Fill the tank with no ethanol, high octane gas and use stabilizer. Run your engine for 5 minutes to get the stabilizer through the system. You are done. If you have or worried about nesting mice, glue traps etc. Do not use poison, the mice eat it, crawl away and stink to high h*ll hidden somewhere. |
09-20-2019, 10:14 AM | #14 | |
Drives: 2013 C6Z06 Join Date: Nov 2016
Thread Tools | |
