Old 06-21-2019, 11:13 PM   #1
Drew145022
Drives: 2017 Camaro 2SS Vert
V6 LT stock brakes to ss rotors
Are the stock rotors for the V6 LT the same size as the SS? I purchased some SS calipers and can’t find a rotor size for them.
Drew145022 is offline   Reply With Quote
Old 06-22-2019, 12:29 AM   #2
DriftNDraft
Drives: 2020 1SS 1LE M6 was 2018 V6 RS A8
2017 V6 LT front caliper is 12.6 in. (13592623). 2017 SS front caliper is 13.6 in. (22991317). Rears cannot be swapped because of differences in the parking brake on LT and SS.
DriftNDraft is offline   Reply With Quote
Old 06-23-2019, 12:08 AM   #3
Drew145022
Thanks I’ll pick up some rotors then. Now I have to decide if I wanna get drilled and slotted or just slotted.
Old 06-23-2019, 03:39 AM   #4
DriftNDraft
The rotors that come from the factory on the SS, SS 1LE, ZL1, and ZL1 1LE are completely smooth - no slots and no drilled holes. The Chevrolet Performance upgrade kit 4- and 6-piston Brembos are slots only. Cross-drilled rotors can develop cracks under severe use around the holes because of larger heat differences just around the hole and the surrounding material. See here: https://www.camaro6.com/forums/showthread.php?t=452333
I personally would get the slotted-only rotors but only because I like the look and my car is street-only.
