06-01-2017, 05:30 PM | #1 |
Drives: 2015 Yellow 2SS LT Z28 cai tune Join Date: Aug 2015
Swapped SW chambered mufflers for 22 dollar summit mufflers.
I changed out my rear mufflers (sw chambered) because it was toooo loud. I talked to sw for a remedy and they told me $600 to change out the mufflers. I got about 60 bucks in 2 summit 18" mufflers and I really like the way it sounds now.Much deeper and quieter in car.
06-01-2017, 05:31 PM | #2 |
06-01-2017, 05:52 PM | #3 |
CAR-DASHIAN
Drives: 2015 Ashen Gray Metallic 2SS/RS L99 Join Date: Nov 2015
Sound clip??
PERFORMANCE: ColdAirInductions CAI, ADM Race Scoop, Cordes Performance Racing Ported TB/IM/Custom VVT Cam, WFO Milled Heads, Stainless Power 1 7/8" LT/3" HFCs, JBA 3" Comp. Cat-Back, Taylor 10.4mm Plug Wires, Tim King Performance Stage 3 6L80, Circle D Billet 3600 Stall, Nic D ECM/TCM Tune, - 458rwhp/413rwtq (prior to PIM), Forgestar F14 (F)18" / (R)17" Rims.
SUSPENSION: Z/28 Rear UCA Bushings, Carlyle Racing LCA/TA, BMR Adj. Toe Rods/Xtreme Anti-Roll Bar, Justice Pete Castor Locks/Radius Rod Inserts, Pegasus Billet Rear Cradle Bushings, Mickey Thompson Street SS II 305/45/17 tires. |
06-01-2017, 06:02 PM | #4 |
no. sorry
06-01-2017, 06:41 PM | #5 |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
Good luck fighting off rust
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
06-01-2017, 07:33 PM | #6 |
06-01-2017, 11:49 PM | #7 |
I used Cherry Bombs of the same size and kinda like it, but think it is almost too quiet some times...
I am LS3 exhaust, catless, and cherry bombs..
2011 2SS/RS Convertible, Victory Red, Roto-Fab CAI, Stainless Power 1 7/8 headers, No Cats, Straight piped, Bo White TB, ZL1 CONVERSION, CDC Roll bar and some powder coating and dipping.
06-02-2017, 04:19 PM | #8 |
That's what I was thinking.
TC should have looked for some stainless mufflers. Probably would not have cost that much more. If he has the full SW catback, I just don't like the idea of putting mild steel mufflers on to that setup. Swap out the SW for some stainless glasspacks and never worry about it again.
2010 CGM Camaro 2SS LS3 Swapped A6 - GPI LS3 SS1 .647/.638, (224/237, 112 +4, 7Ί overlap) on CamMotion 8620 core, BTR Platinum .660" Dual Spring kit w/titanium retainers, CHE bronze trunnion upgrade, stock heads milled @ .015, Melling HV 10296 oil pump, TSP 1-7/8" long tube headers (W/Catless Off-road Pipes), Corsa Xtreme 3" Catback, GPI Ported/Rod Mod Intake, Stage 2 Ported Throttle Body, Vararam OTR CAI, Mike Norris Gen 2 catch can + GM 1LE clean side separator, 160Ί thermostat - Megan Racing adjustable coilovers (lowered 1.75"), MRR M017 10/11" wheels-Tuned by Ryan @ GPI
06-08-2017, 12:41 AM | #9 |
Drives: 2010 2SS/RS LS3 A6 IOM Join Date: May 2013
I have the SW exhaust as well, loud with LTs, need to tone it down a bit now that the SS is cammed.
