01-29-2017, 09:43 AM | #1 |
Drives: 2018 1SS M6 Join Date: Nov 2014
Fob Programming
Hey y'all,
I did a search but couldn't really find anything definitive on this for post key recall, and the owner's manual says take it to a dealer. I could only seem to find threads dealing with a new key, but not the fob. I just bought a new fob as the old ones were falling apart. Is there a DIY procedure to program it to my 2011 SS, or is this a dealer only procedure? Thanks for your help. |
01-29-2017, 09:47 AM | #2 |
Drives: 2018 Camaro 1SS/1LE Join Date: Feb 2015
Since you have the originals, can you just remove the internals from the old and put it in the new one?
01-29-2017, 09:53 AM | #3 |
Ha, I just thought about that as I was writing the post. Thing is, I'd hate to get it all apart and not be able to get it back together for one reason or another.
01-29-2017, 11:18 AM | #4 |
Montani Semper Liberi
Drives: 2011 Black 2SS/RS w/ IOM stripes Join Date: Feb 2010
is it the old fob and key together? if it is then just find the relearn procedure on here, http://www.camaro5.com/forums/showthread.php?t=93145
Stainless Works 1 7/8 Long Tude Headers, Stainless Works High Flow Cats, Stainless Works Retro Chambered Catback, Z/28 Air Intake, RDP Tuned, FR41 Chrome Rims, 1100W stereo, 35% Tint |
01-29-2017, 12:33 PM | #5 | |
01-30-2017, 06:27 AM | #6 | |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
Or take it to the dealer and they charge a flat 1 hr fee and keep you car most of the day. |
01-30-2017, 08:09 AM | #7 | |
Drives: Miss Con Ception Join Date: Aug 2016
2011 1SS/RS LS3 CGM
01-30-2017, 10:22 AM | #8 | |
If so then have the key cut and perform the relearn procedure on the new fob & key. If not then try this. Take your recall key off your fob and leave the fob in the house. Start your car with just the key to test that the car will start .... it should. Then do the relearn procedure using your recall key ... put it in the ignition turn to ON (but don't start) until the security icon disappears. Then take it out and attach the key to your new fob. Put the key in the ignition and turn to ON (but don't start) until the security icon disappears. You should see a DIC msg saying something like Key Added. Then start your car and test all the fob buttons. |
01-30-2017, 12:24 PM | #9 |
AKA "Beefcake"
sorry, my 'assumption' was you had the key with fob purchase. Not Just the fob. Even "post-recall" you can buy switchblade keys for the Camaro and program them. My bad. you could of gone that way also and just take the fob apart from the key and put it on your old key, and have a spare key without a fob.
01-30-2017, 12:26 PM | #10 |
Drives: 15 Z28, 01 Corvette, 96 Corvette Join Date: Dec 2016
The key comes off... its just a key and a remote stuck together.
Put the old key in the car and program the new remote.
2018 Sierra RCSB | 2015 Z28 Camaro | 1989 B2200 with a 327 | 1996 LT4 Z51 Corvette | 1973 427 Nova
01-30-2017, 02:05 PM | #11 | |
Drives: 2018 Camaro Join Date: Oct 2016
for my son's 2015 Camaro. Drove to the locksmith who laser cut the key and reminded me not to use the switchblade key because in case of an accident, my insurance company will not cover me if they find out the switchblade key was used to drive the car (Key Fob Recall). Anyhow, I followed the Key Fob "relearn" procedure (above) and 10 seconds later it was working and I started the car in the locksmith's parking lot. |
01-31-2017, 02:05 AM | #12 | |
I tried the quick method that camguynj posted with no result. I'm a little nervous about the more detailed method mentioned from the other thread. I'd hate to trip a security function and brick the BCM. |
01-31-2017, 06:21 AM | #13 | |
If 2, did the key start the car but didn't program the new fob? Does the new fob have a key in it ( ie. is it a switchblade fob) ? 1) If so then have the key cut and perform the relearn procedure on the new fob & key. 2) If not then try this. Take your recall key off your fob and leave the fob in the house. Start your car with just the key to test that the car will start .... it should. Then do the relearn procedure using your recall key ... put it in the ignition turn to ON (but don't start) until the security icon disappears. Then take it out and attach the key to your new fob. Put the key in the ignition and turn to ON (but don't start) until the security icon disappears. You should see a DIC msg saying something like Key Added. Then start your car and test all the fob buttons. |
02-13-2017, 01:28 PM | #14 |
Update
Well, after all the attempts failed to get that FOB to program. I tried to DIY it and swap the faceplates. Don't try this, the glue is stronger than the plastic.
So today, I took the car in because I had a screw in the tire. While I was there I talked to the parts dept about the key. Turns out that part of the purchase is to cut the new key. Wasn't told anything about that when I bought the first, probably why it wouldn't program. So I bought another, $59, and they cut it for me. So I am now the proud owner of a brand new working switch blade key from the dealership. So much for the recall key. |
