08-16-2016, 04:04 AM | #1 |
Drives: 2015 Yellow 2SS LT Z28 cai tune Join Date: Aug 2015
GM Dexos oil
Anybody else use the factory oil? I get it at my dealer for 3.90/qt. im running it in my 2015 ss ,2012 5.3 sierra and my wifes 09 saab. all 3 seem to "like" it.
08-16-2016, 08:34 AM | #2 |
Drives: 2004 GTO & 2005 GTO Join Date: Mar 2014
It's just synthetic oil you can buy anywhere.
Go to any place that sells oil. Nearly all synthetics now have the "Dexos" stamp. |
08-16-2016, 09:05 AM | #3 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
Isn't it just a synthetic blend, and not a full synthetic?
I just buy 5 qt jugs of full synthetic (either mobil1 or pennzoil platinum) from walmart for $22.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
08-16-2016, 09:06 AM | #4 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Yes, I also believe it is a synth blend, and not a true synthetic (not trying to open a debate on what a "true synth" is...). I opted to move on to RP, but would use most major full synthetics over the GM.
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
08-16-2016, 09:36 AM | #5 |
Drives: 2010 Camaro Join Date: Nov 2009
Dexos is only the designation similar to API, your engines listed are GDI engines, so make SURE it is not a synthetic blend as that adds to the intake valve coking issues they all suffer from. Only use full synthetic.
08-16-2016, 09:40 AM | #6 |
All that makes a difference while under warranty is that you buy an oil that's dexos approved. I buy the cheapest dexos approved oil for my wife's '15 Cruze, and use Mobil 1 in the Camaro (which happens to be dexos approved as well).
Yeah, opening the oil debate will just turn into a shit storm. |
08-16-2016, 09:46 AM | #7 |
Drives: 2014 2LT RS Join Date: Apr 2015
here is a list of approved dexos oils, not just the dealer brand
http://www.centerforqa.com/dexos-brand1/ they have additives that GM decided are needed to maintain your warranty |
08-16-2016, 02:09 PM | #8 |
Didn't mean to open up a debate, just a firm believer in getting full-synth in these cars and letting OP know that the GM stuff is a blend.
08-16-2016, 08:07 PM | #9 |
Its all good. this is my 3rd ls engine and have maintained a few hundred through the years. I like semi because it seems to not burn as much oil between oil changes. I noticed this a while back with a customer with a fleet of 6.0 chevy trucks that are used to transport auto glass. They would supply the amsoil 5-30 and go 15000 between oil changes and they ALWAYS came in 2-3 qts. low. I ran some regular run of the mill dexos 5-30 (private label sure guard) in a few of them just to see and they were never low coming in.
08-16-2016, 09:46 PM | #10 |
Lifetime Philly Fan
Drives: 2015 Spring Edition 2SS M-6 Join Date: Mar 2012
The factory Dexos oil that is in my Green Flash is a blend of synthetic and Dino oil. They pay for it and do the oil changes, it's fine with me.
If/when the time comes that I start doing my own, I will change it over to fully synthetic Mobil One.
2015 Green Flash, Delivered 4/10/15
CAI, NPP Exhaust, Short-throw shifter BBK LT HEADERS 1 7/8” Tune by DynoSteve via SCTx4 Tuner One of 82 GF Ragtops built in '15 out of 811 Total [/SIZE] |
08-16-2016, 10:08 PM | #11 |
Drives: 2015 Camaro Convertible 2SS RS Join Date: Jun 2016
He's got a '15 SS - don't think that's GDI, is it? That's 2016 that went to GDI
08-17-2016, 06:04 AM | #12 |
Drives: 2011 Camaro 2LT/RS Join Date: May 2015
I use Dexos 1. GM is changing Dexos to full synthetic.
