Old 05-23-2019, 04:46 PM   #1
oldman
Drives: SS 6 speed of course
OK stupid question on ZL1 shafts into a SS
I know the Chevy performance offers ZL1 axle shafts for the SS, don't know if they are the same length i.e. is this a zl1 "style" shaft cut to an SS lenght OR ZL1 axle shafts bolt in?
the second question, we know GM performance offers an Zl1 automatic driveshaft for the SS, but the do NOT offer a Zl1 shaft for the manual. To make it even MORE confusing, when the GM performance shaft was announced it was listed for both auto and manual.
I check the 2016 SS manual driveshaft part number it is 84306999
I check the 2017 Zl1 manual driveshaft part number it is 84306999
So correct me if I'm wrong it looks like the 2016 SS driveshaft manual is the ZL1 shaft auto or manual...
Or since the ZL1 verts have the standard SS diff, GM uses the same shaft?
I also show 84100512 as a zl1 manual drive shaft...
Old 02-29-2020, 09:15 PM   #2
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Hey oldman, so the stock ZL1 half shafts fit the SS? Or do I have to buy the GM Performance 84398126 ones?
Old 03-01-2020, 06:12 AM   #3
wnta1ss
Drives: 2017 Camaro 1SS
Check out that thread in the member car section, something like Camaro Drag Program build. He has pictures of the axle upgrade in there.
Old 03-01-2020, 10:41 AM   #4
Trochoidal
https://www.camaro6.com/forums/showt...=538617&page=4
Old 03-01-2020, 11:52 AM   #5
Joshinator99
Originally Posted by Trochoidal View Post
Those both refer to the Chevy Performance Kit designed to retrofit the ZL1 style axles into an SS, so I’m wondering if Chevy makes them specifically for that purpose. In other words, they might not be bone stock ZL1 axles? Can you just take stock ZL1 axles out of a ZL1, and bolt them into an SS?
Old 03-01-2020, 12:07 PM   #6
Trochoidal
The shovel is out and I’m digging for some data on this swap. From a couple of older threads I’d say that stock ZL1 axles are going to be shorter because of the ELSD. If that’s the case the GM Performance 84398126 is probably longer.
https://www.camaro6.com/forums/showthread.php?t=483518
Old 03-01-2020, 06:24 PM   #7
oldman
for memory, only one side of the eLSD is different anyway ( in length not strength). The ZL1 convertible comes with different axle (one side) the regular ZL1 non-vert. I have only changed the driveshaft so I don't have all the data on the axles (sorry engine rebuild and HP seeking got in the way).
