Old 05-15-2019, 02:25 AM   #1
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
are they using the hybrid syncros in the t6060 from the factory now?
got the 2 gear grind bad. i need to change out the fluid to Amsoil ATF and flush the brake fluid.
Old 05-24-2019, 05:19 PM   #2
red6.2
Drives: 2010 camaro
did you fix the the 2 gear issue with fluid change?
red6.2 is offline   Reply With Quote
Old 05-24-2019, 05:46 PM   #3
JCunningham
Drives: 2017 2SS M6
havent had a chance to. got Amsoil ATF and a hurst shifter to put in
Old 05-24-2019, 05:49 PM   #4
red6.2
Drives: 2010 camaro
okay i will let you know if it fixes mine. Im going to change mine in 2 weeks!
Old 06-17-2019, 06:38 PM   #5
red6.2
Drives: 2010 camaro
alright so i have a good news! I could get into gear way more easier now. Really a night and day difference. do it asap, you will be happier. I used amsoil atf. 2nd gear grinding is almost not existent and all the gears shift better. Now these cars will never shift like a honda or a subaru (that easY..). they want to be shifted hard. if you do you will have no issues.
Old 06-17-2019, 10:16 PM   #6
JCunningham
Drives: 2017 2SS M6
everyone says they have trouble when shifting easy. mine wont shift unless i take it very easy. I cant through it into 2nd at 6000rpm. I have to slowly put it into 2nd or it will grind and not go into 2nd. I just bought a Danmar M6 lift but found out the ass holes at Morton Building only poured my garage floor 2". you need a minimum of 4". 3" is code.
