Old 05-13-2019, 09:06 AM   #1
tecmec
Drives: 2016 2SS
Brake fluid reservoir with screw-on cap?
To make a long story short, I hate the three-prong reservoir cap on my 2016 Camaro SS. It's nearly impossible to get a good seal with my Motive speed bleeder, and it only gets worse at the bleeder's gasket ages. My Focus ST had a threaded reservoir cap, and it worked so much better.
So I was reading on the motive website, and I found this: "Starting with some later Chevy cars, such as the new Camaro, have started to use a female threaded cap that screws on 1.5 to 2 full turns and is 45mm (1.75") inner diameter it will use the 1100 or 1109 adapter." That sounds great! The 1100 is the adapter that I used on my old ST. But is this actually true?
Do any of you have a 6th gen Camaro with a brake fluid reservoir with a screw cap? If so, what year is your car? And if such a brake reservoir exists, does anyone know the PN? I did a quick browse on the GM parts websites, but the diagrams still look like three-prong twist caps, even on the 2018. (Though I know the diagrams on those part sites are not always the best.)
tecmec is offline   Reply With Quote
Old 05-13-2019, 08:56 PM   #2
Jsreo
Drives: 2017 2SS Manual
My 2017 has the 3 prong cap as well. the metal adapter, version #1118 works ok for me up to 15 psi using the thicker gasket but it is hard to get on the reservoir.
The plastic adapter leaks no matter what I do
Jsreo is offline   Reply With Quote
Old 05-17-2019, 09:39 AM   #3
tecmec
Drives: 2016 2SS
Hmm...Not a lot of replies, so maybe to try a different way: people with 2019s, what kind of cap do you have on your reservoir?
Sent from my Pixel 3 using Tapatalk
Old 05-17-2019, 01:32 PM   #4
DeadSpider
Drives: 2019 Camaro SS 1LE
behold...
DeadSpider is offline   Reply With Quote
Old 05-17-2019, 01:33 PM   #5
tecmec
Drives: 2016 2SS
Damn. I wonder where Motive is getting their info.
Old 05-17-2019, 03:27 PM   #6
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
The three prong adapter only fits leak free in 1 of the three possible positions. Once you install the motive adapter gently rock it and see if it is solidly attached. It will rock in the 2 bad positions. This is accurate for 5th & 6th gen cars. I discovered this after making a few mistakes and drowning my inner fenders with brake fluid.
Stephen12ZL1 is online now   Reply With Quote
Old 05-21-2019, 08:41 PM   #7
OVRKLL
Drives: 2017 1SS 1LE...makes me go YeeeHaw!
This is interesting, I was going to flush my brakes, but I guess I best do a good pressure check first.
So does the plastic cap work at all?
Or is it useless?
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late!
OVRKLL is offline   Reply With Quote
Old 06-01-2019, 06:48 PM   #8
Stephen12ZL1
Drives: '21 ZLE A10
Or is it useless?
plastic cap works fine if correctly clocked
