Old 05-07-2019, 09:04 PM   #1
samjlee27
samjlee27's Avatar
Drives: Summit White 2018 Camaro 1SS M6
Is this normal?
Have had this issue where if I rev the engine in neutral the revs will slowly fall. First noticed this after installing a CAI at around 10000 miles. If I rev it enough though it will fall normally as shown in the video (unless the car is in gear in which it will always fall slowly). This issue is intermittent, most of the times it will act like this but some times it will go back to how I remember it being before installing the CAI. I’ve disconnected the battery multiple times, taken the CAI out and back in, tightened all the bolts
samjlee27 is offline   Reply With Quote
Old 05-08-2019, 05:35 AM   #2
mrgoodbytes
mrgoodbytes's Avatar
Drives: '18 2SS/EU (+Recaros) M6 Red Hot
Revs hanging could likely be caused by an intake vacuum leak (ie. after the throttlebody). Have you checked all hoses?
mrgoodbytes is offline   Reply With Quote
Old 05-08-2019, 07:21 AM   #3
samjlee27
samjlee27's Avatar
Yup, checked everything can't figure out for the life of me the issue.
Old 05-08-2019, 07:30 AM   #4
Baldilocks01SS
Baldilocks01SS's Avatar
Drives: SEARCHING
Throttle position sensor?
Baldilocks01SS is offline   Reply With Quote
Old 05-08-2019, 02:53 PM   #5
samjlee27
samjlee27's Avatar
How would I check for that??
Old 05-11-2019, 11:31 AM   #6
VinnAY
Drives: 18 1SS/1LE
Its not an issue...Its for emissions, not letting the throttle snap closed suddenly (supposedly) when letting off the gas helps the emissions profile, a ton of cars have it.
Old 05-11-2019, 05:45 PM   #7
samjlee27
samjlee27's Avatar
But I didn't have this before installing the K&N CAI which is leading me to suspect that something is wrong
Old 05-12-2019, 07:03 AM   #8
VinnAY
Drives: 18 1SS/1LE
You didn't notice it perhaps. Might be easy to pull the K&N and then reevaluate it
