Old 04-26-2019, 10:58 PM   #1
mano_camaro
IYAOYAS
mano_camaro's Avatar
Drives: 22 1LE 2SS M6 Riverside Blue
is my rear half shaft broken?
I started hearing a knocking sound from the rear end passenger side at low speeds after my first track day with this camaro SS (my previous V6 didn't have issues using the same setup). I checked the bolts connecting to the rear differential, and they are still tight with the colored marks still matching lines, i seen some members show their bolts coming loose, but not in this case. I performed a tug on the half shaft while i was replacing the rear differential fluid and it has just a little bit of play but the rear sway bar also has the same amount of play.
Could it be the stiff BMR trailing arm upgrade having something to do with it, Since it is transferring more power to the tires?
2022 Riverside Blue Camaro 2SS 1LE/ PDR
2020 Red Hot Camaro 2SS 1LE/PDR /Sold
2018 black Camaro 2SS M6 Redline Edition/Traded
2016 summit white Camaro RS V6 M6/Traded
mano_camaro is offline   Reply With Quote
Old 04-29-2019, 11:57 AM   #2
Mountain
Mountain's Avatar
Kinda looks like an odd angle, but it's hard to really call it from just the visual. I've seen boots roll/bind into weird angles, making it look like something was FUBAR.
Can you clarify as to whether that BMR control arm was or was not on your V6?
Old 04-29-2019, 01:13 PM   #3
mano_camaro
IYAOYAS
Yeah, the BMR lower trailing arms were installed previously on the V6.
I will try to jack it again tonight and check bushings on outer trailing arms, and add better pictures.
