Old 04-21-2019, 04:50 PM   #1
f.d
Drives: camaro
STP Fuel additive problem
Hello everyone..
I used STP Fuel additive for no reason ( i thought it’s something good for the injectors).
I used STP 5-1 Fuel System Cleaner.
Now I have leaking injectors:
Lost the performance, fuel smell for very long time in cold start.
1- The car running too Rich. LTFT - 23% scanning.
2- fuel in the engine oil. 😵🤯
No codes
Don’t ever never use STP fuel cleaner.
New 2018 Camaro SS Auto
8000 km
I don’t know what to do!!
Now: I feel like the car start to come back to the life after 2000 km driving, and i changed engines oil, but the fuel getting in the oil pan again.
I will change the engines oil again and see what will happen.
Hope to STP effect expires
Hope you get some warning ⚠️
Don’t do what I did.
Good luck 🍀
f.d is offline   Reply With Quote
Old 04-21-2019, 05:27 PM   #2
mrgoodbytes
mrgoodbytes's Avatar
Drives: '18 2SS/EU (+Recaros) M6 Red Hot
That is crazy. Do you know which of the injectors are leaking?
Will you be troubleshooting/fixing it yourself or going to a dealer?
mrgoodbytes is offline   Reply With Quote
Old 04-21-2019, 06:59 PM   #3
f.d
Drives: camaro
It looks all injectors, but I’m going to a workshop 29/April to diagnose , hopefully leaking stops before.
I don’t now, I’m tired.
I will update.
Tomorrow i will change the engines oil again, the engine is suffering cause off the fuel leaking.
Old 04-22-2019, 04:12 PM   #4
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
Well, sounds like more than the STP as the problem. Nevertheless, these engines do not require additives and in fact, they should be avoided. Good quality fuel and GM designated oil is all they need. I hope you get the problem corrected soon!
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 04-23-2019, 12:00 PM   #5
f.d
Drives: camaro
Thank you ���� my friends ��������
Today I changed the oil the second time, engines oil smell a way better ( not to much fuel smell), I think the problem start to disappear.
Scanning shows (LTFT -8 %) bank 1 and bank 2 also.
Hopefully 100% disappears next 500 mil or 1000 mil.
I hope to everybody get the warning.
I will update next week
Thank you again
Old 04-29-2019, 02:27 AM   #6
f.d
Drives: camaro
God morning.
Today is the day
Bank 1 LTFT is 0%
Bank 2 LTFT is 0%
Don’t ever never use STP 5-1 Fuel cleaner.
If you will use it, on your own, and don’t add all the bottle, be wise.
I hope you all get the warning.
Good luck ��
Old 04-29-2019, 03:12 AM   #7
mrgoodbytes
Hi f.d thank you for your feedback. Great to hear you got the car sorted again.
Btw, where are you located in Sweden? I am in Skåne.
Old 04-29-2019, 03:51 PM   #8
f.d
Drives: camaro
Hello!!
Thank you
I’m in Laholm
Old 05-20-2019, 10:25 AM   #9
f.d
Drives: camaro
The problem is back
After changing engines oil the LTFT is -1%, but few days later it’s go to -14% and -16%
It’s really Rich mixture.
LTFT is -6 % while driving, and go to -15 % when i release the throttle.
Oil smell fuel little.
I think, I really have injectors leaking.
any body have idea?
Help!
Old 05-24-2019, 11:36 AM   #10
6spdhyperblue
Drives: 6th gen
Minus 6 is within normal. -15% off throttle is also normal it’s hitting dfco
What are the stft?
If u had leaking injectors you’d know it.
Old 05-26-2019, 07:56 AM   #11
TedJS
Drives: 2016 Camaro SS
I think you are driving yourself crazy over nothing. You are seeing a final correction to the base injector pulse width that is completely normal. As long as short term is at or near 0% the system is fine. Probably seeing a periodic correction due to the canister being loaded with fuel vapors etc.
Enjoy your car.
TedJS is offline   Reply With Quote
Old 05-28-2019, 02:40 AM   #12
f.d
Drives: camaro
Thank very very much for reply.
Every time i change engines oil, the car be perfect and ( LTFT ) go around 0% .
But after 2 days ( LTFT ) go to negative like -5% -10%
And the oil smell fuel
Old 05-31-2019, 02:33 PM   #13
f.d
Drives: camaro
I bought the fuel injectors on line for my car today.
I’m just waiting for the dealer to give me reply if the replacement number fits my car.
Please question do I have to update the ECU for the new injectors?
Or just replace them?
Old 06-02-2019, 08:05 PM   #14
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
The ONLY fuel injector cleaner you should use is Chevron Techron. Its what GM sells- rebadged.
STP is JUNK
