Old 01-04-2019, 04:56 PM   #1
retmil
Drives: 2022 Wild Cherry SS
M6 2nd gear issue
A few months ago I opened a thread on the issue I have with going into 2nd gear - hard to get trans into gear. All other gears are fine and down-shifting presents no problem. I swapped fluid to Royal Purple and no real improvement. I have been told that the synchros are harder/cut different for lower gears. I really hate to tear into the trans as car only has 2677 miles on it. Any suggestions? I am open to all input. Thanks!
retmil is offline   Reply With Quote
Old 01-04-2019, 07:14 PM   #2
red6.2
Drives: 2010 camaro
to be honest this is the car that i ever had trouble with on 2nd gear. first i drive 1 to 4 for like ten minutes. people behind me HATE me. not my fault, its what my car desires and likes. then after i realize the transmission when getting into 1 gear is easy, i shift at 3k on 1st gear to 2nd gear and so forth. it grind sometimes and clunk. what i been told is that 2nd gear synchros are problematic. i have been driving my car harder now like a 18 year old with his first 6 speed and i am enjoying the car even more then when i first bought it. IT WILL SHIFT SMOOTH. i work hard to pay for my Camaro and i have took it to dealer twice for this problem. they can't find a ISSUE with it. I don't want to abuse it since I'm paying for the car with my own hard earned money but I'm not (not going enjoy it because the car likes (has) to be driven hard to work well. hope everything goes well with your car but since the dealer knows you swapped the transmission fluid your screwed on that part. enjoy it while you own it
red6.2 is offline   Reply With Quote
Old 01-04-2019, 07:51 PM   #3
gotroost
gotroost's Avatar
Drives: 2021 Crush ZL1 1LE
Possibly the skip shift BS. Mine is kinda flaky. Will sometimes shift into 2nd even when the 1-4 warning is displayed and sometimes doesn't like 2nd without the warning. Keep the RPM up a little higher in 1st and all is happy.
2021 Crush ZL1 1LE
gotroost is offline   Reply With Quote
Old 01-04-2019, 11:51 PM   #4
2SSAustin
Drives: 1LE 2SS Camaro
As mentioned above. If I drive it really nice it seems to be tougher to get into seconds gear. But if I go to 3000+ Rpm and shift it will be smooth. Also check what your trans temps are with the display screen if you can. I notice when its cold it is more problematic.
2SSAustin is offline   Reply With Quote
Old 01-06-2019, 01:51 PM   #5
retmil
Thanks for the replies. I have the skip-shift eliminator installed so the issue is not related. Also, temps do noy appear to affect shifting too much either. Today I went out and did try shifting at around 4K and problem almost gone but I really don't want to have to shift at that point in everyday traffic. I guess I will just have to live with the problem.
Old 01-06-2019, 02:56 PM   #6
red6.2
Drives: 2010 camaro
Sorry buddy but I told you. Lol the car likes to be driven hard! Now everyone and their grandma is going to think you are racing them.
Old 01-08-2019, 04:01 PM   #7
retmil
Thanks again. I will just start driving it like I stole it.
Old 01-18-2019, 06:34 AM   #8
mrgoodbytes
mrgoodbytes's Avatar
Drives: '18 2SS/EU (+Recaros) M6 Red Hot
Do you have active rev-match enabled?
In my experience, the gearbox can be a little clonky going from 1st into 2nd gear, when active rev-match is enabled at slow speeds. I think it is because it tries to match revs when up-shifting.
Another thing. When depressing the clutch pedal are you sure that it is fully depressed? Try if you can depress it just a little further and see if that helps.
These two things have helped for me. I was also very frustrated with this at first, but have come to love the gearbox.
mrgoodbytes is offline   Reply With Quote
Old 01-18-2019, 07:04 AM   #9
Deakins
Drives: 2017 2ss, m6
When you say "down-shifting presents no problem" does that mean you can downshift into 2nd gear without the issue?
Deakins is offline   Reply With Quote
Old 01-21-2019, 02:46 PM   #10
retmil
Sorry for the delay in answering - there is no issue when downshifting from 3rd to 2nd.
Old 01-21-2019, 02:48 PM   #11
Whocares05050
Drives: 2018 Camaro SS 1LE
Which royal purple fluid did you swap in? There are 2 different ones and 1 works better than the other.
Whocares05050 is offline   Reply With Quote
Old 01-21-2019, 10:47 PM   #12
Calcanuck
Calcanuck's Avatar
Drives: 2017 Hyper Blue 2SS
Which one works better? I am do for a change and want to use the right stuff
Hyper Blue 2SS, 6MT, NPP, 6 piston Brembo, 1LE suspensions upgrade, ZL1 Seats, Wheels & Tires
Calcanuck is offline   Reply With Quote
Old 01-21-2019, 11:47 PM   #13
waterman
waterman's Avatar
Drives: Grandad's C2 L89
Your installed skip shift eliminator could be the issue.
If you always accelerate in first gear to 18-20 MPH (less than 2400 RPM), skip shift is eliminated automatically by the ECU. Your LT1/4 would rather rev than lug.
IMHO, constantly utilizing skip shift during break-in, may ultimately prove be detrimental to long term gear/synchro performance.
Who would have thought to even consider to shift from 1st to 4th to save a little fuel, before the EPA mandates?
2018 ZL1 1LE sw/PDR
Old 01-22-2019, 06:30 AM   #14
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2019 GMC Sierra 1500 AT4
My first (and sometimes second) 1-2 shift of the day is always pretty notchy. If I'm not careful, I won't fully engage second and it will pop out of gear and make a bad "grind" noise. It's only when the transmission is cold (sat all night cold), and only on the first one or two 1-2 shifts. This is been the same on each of my gen 6 cars.
Summit White
6" Lift, 37x13.50R24's
geaux_tigerss is offline   Reply With Quote
