09-15-2018, 08:41 PM | #1 |
Drives: 2017 SS 1LE Join Date: Sep 2018
Mbrp exhaust and check engine light on
Hey guys, i have the mbrp exhaust on my 17 SS 1le.
Now the check engine light stays on. What do I need to do to get this turned off but not affect my other check engine light sensors?? Thanks |
09-15-2018, 10:21 PM | #2 |
Drives: 2017 1LE Join Date: Nov 2017
hook a reader to it and see code? Probably just a leak. Cat or axle back? Code typically is forward, not rear.
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube |
09-17-2018, 06:51 AM | #3 |
If it's a catback might have a leak up front. No reason an axleback would get you a CEL.
09-17-2018, 02:01 PM | #4 |
09-17-2018, 10:21 PM | #5 |
Leak.
05-23-2019, 07:31 AM | #6 |
Drives: Chevrolet Camaro 1SS Join Date: Apr 2019
Does your camaro have the feature which allows stealth mode, etc? Just took my 2017 1ss to the shop to have an mbrp race cat back installed. Mechanic said that the last 2017 camaro ss he put a flowmaster on caused a CEL to come on for something with the fuel pump. Weird. Hoping this doesn't happen to me.
05-23-2019, 08:30 AM | #7 |
Drives: 2016 Camaro 2SS Summit White Join Date: May 2016
05-23-2019, 10:50 AM | #8 |
Drives: 22 ZL1 M6 Join Date: Oct 2018
probably a leak. installed same exhaust on my m6 no codes. been about 3 weeks
05-23-2019, 11:09 AM | #9 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
It's a leak recheck your clamps, pull your negative off the battery and try again
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
