06-23-2018, 10:53 PM | #15 |
Drives: FIFTY 2SS Callaway Join Date: Sep 2017
I am having the same issue after installing the the darkened taillights and third brake light on my 2SS. Any recommendations?
Thanks, |
06-24-2018, 08:19 AM | #16 |
Drives: 2016 Camaro SS Join Date: Feb 2017
Are the ones in the front lighting up?
Also check all fuses labeled "Body Control Module" (or just "BCM") in your fusebox. Don't remember which numbers they were, but two of them are related to the turn signals. Replacing the blown fuse(s) fixed the issue for me. |
06-24-2018, 08:30 AM | #17 |
Drives: Love the one you're with Join Date: Sep 2009
Your need to change your blinker fluid to full synthetic when you convert to LED.
06-24-2018, 10:38 AM | #18 |
Drives: 2018 2SS Join Date: Aug 2017
Try your hazards. Do they blink at the same rate? I recall on my Harley that running these after an LED swap calibrated the BCM.
06-25-2018, 12:19 AM | #19 | |
Hazards usually never hyperflash. |
12-05-2018, 01:11 PM | #20 |
Drives: 2018 camaro 1ss Join Date: Oct 2018
Having the same issue. Hazard blink normally. I got 3-4 blinks on passenger then it doubles speed. I’m talking to the people I got the tail lights from so hopefully we can figure this out. Also the front blinkers are working normally
07-23-2019, 10:33 PM | #21 |
Drives: 2018 SS 1LE Join Date: Aug 2017
The tailight that has the problem is defective. Return it for an exchange.
