Old 10-20-2016, 01:25 PM   #29
oldman
Drives: SS 6 speed of course
Originally Posted by TSloper View Post
19303897
LT1 Hot Cam NEW!
I: .577 / E: .577
I:228/E:248
116.5
Design for 1.81:1 rocker arms; requires non-afm lifters (See warranty statement on page 35)
I like it from my LS1 days, I get scared at high lift street cams, rocker trunion, valve spring and pushrod failures. .577, I'll give up 15 HP for 100,000 mile no issues. Most cams for the LT1 are like .627
Old 10-20-2016, 01:58 PM   #30
6spdhyperblue
Drives: 6th gen
let me guess, our stock Rocker arms are not 1.81? and GMPP sells those rockers?
Old 10-20-2016, 02:13 PM   #31
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
19303897
LT1 Hot Cam NEW!
I: .577 / E: .577
I:228/E:248
116.5
This would be a 'mild' cam? Lower lift so not so choppy like a .65?/65?.
Longer duration as well?
So better flow and RPM usage.
Sorry, thats my basic cam knowledge for now. It's been awhile...
Old 10-20-2016, 02:27 PM   #32
6spdhyperblue
Drives: 6th gen
just from looking at the numbers and a simplified overlap calculation of plus 5*, I would say it will be a pretty choppy idle.
but it WILL have stable idle, giving good vacuum, and still delivering good torque for a excellent street/strip setup.
the lift can be looked at as power curve amplitude. the more lift, the more you raise the curve, just as it sits, across the entire RPM band
moderate lift numbers, you sacrafice a little power for spring life. although power from lift is not linear..if you really know what you're doing(being that they sell the heads with the cam, i would expect they did this)...you can look at flow characteristics, also valve stability. if you hammer the valve to the point that it flutters, you'll lose power and greatly reduce spring and lifter life. beneficial to stay away from that condition to say the least
Old 10-20-2016, 08:49 PM   #33
Fast6.3
Fast6.3's Avatar
Drives: 2016 2SS coupe 2015 3LT Stingray
The kit doesnt mention it but do you need the phase limiter
Ported intake manifold and throttle body kooks 2" headers no cats
Fast6.3 is offline   Reply With Quote
Old 10-20-2016, 09:35 PM   #34
ULTRAZLS1
ULTRAZLS1's Avatar
I think the stock rockers are 1.8
Old 10-21-2016, 11:53 AM   #35
Fast6.3
Fast6.3's Avatar
Stock rockers are 1.8
Old 10-21-2016, 06:30 PM   #36
Donner
Drives: 2017 50th SS convertible
Inquring minds want to know.
Originally Posted by jayb998 View Post
Just got in the hot cam and CNC heads form GM Performance parts today for my 2016 m6 camaro should be in the shop in a couple weeks, gotta get the tuner free to come tune it. My local dealer is doing the install and is going to stand behind all the parts and labor during the factory warranty period. Im going to get some before and after runs on the same dyno for comparison.
Hello,
Please keep us updated on the process. I've been mulling those options over for a few days now and really would like to know what to expect.
Kindest,
Donner
Donner is offline   Reply With Quote
Old 10-21-2016, 08:35 PM   #37
icon_636
Drives: 2014 Lincoln MKZ
Originally Posted by Donner View Post
Hello,
Kindest,
Donner
+1
icon_636 is offline   Reply With Quote
Old 10-21-2016, 10:14 PM   #38
Blk16SS
Blk16SS's Avatar
Drives: 2016 Chevy Camaro
I wonder what percentage of a fuel pump lobe the new hot cam comes with... Could use a 38% increase for a future supercharger
Blk16SS is offline   Reply With Quote
Old 11-01-2016, 09:29 AM   #39
Master357
Master357's Avatar
Drives: 2017 1LE
http://www.hotrod.com/articles/new-l...cam-tensema16/
I'm assuming this is the same cam and head combo.
So here are all the numbers we could expect from it.
Master357 is offline   Reply With Quote
Old 11-01-2016, 09:58 AM   #40
6spdhyperblue
Drives: 6th gen
around 75hp? is that right?
Old 11-01-2016, 10:15 AM   #41
Master357
Master357's Avatar
Drives: 2017 1LE
Sure looks like it.
Old 11-01-2016, 10:17 AM   #42
slick3
Drives: Garnet Red - 20 ZLE
Yeah at the crank. so about 60 -55 at the wheels? Sounds like a legit upgrade to me! I wonder what the curve looks like.
slick3 is offline   Reply With Quote
