Old 09-06-2017, 01:39 PM   #183
jayb998
jayb998's Avatar
Drives: 2016 2SS M6
so just a question I came across a lt4 blower setup cheap would this heads and cam work with FI
jayb998 is offline   Reply With Quote
Old 09-06-2017, 01:42 PM   #184
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Yes it should work fine.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 09-06-2017, 03:19 PM   #185
DFW1LE
DFW1LE's Avatar
Work yes, but most likely would not be optimal. I'd look into a PD cam if you want to go in that direction in the future.
Old 09-13-2017, 05:21 PM   #186
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
So what else that's not included is needed to install this kit and have a true 100,000 mile setup?
Aftermarket DOD/AFM delete kit?
Katech valley cover?
Comp Cams phase limiter?
Comp Cams trunion upgrade kit?
C5R timing chain?
oil pump?
I'm sure some gaskets and what not, kit just seems a little imcomplete.
JonDaddy82 is offline   Reply With Quote
Old 09-13-2017, 09:21 PM   #187
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
C5R timing chain?
oil pump?
Order
GM cam package - hot cam and CNC ported heads.
This Kit Includes:
19303897 (1) Camshaft
12595365 (4) Valve Lifter Guide
12648846 (8) Valve Lifters
19329839 (2) CNC Cylinder Head Assembly
Comp Cam phaser
AFM/DOD Delete Block Plug Tool Kit for GM Gen IV & V V8 Engine Blocks
Various gaskets
Tune
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 09-14-2017, 08:15 AM   #188
jayb998
jayb998's Avatar
Drives: 2016 2SS M6
mine did not come with a cam phaser limiter or an aftermarket delete kit but a tap and plugs. and there were no different timing chain or oil pump because mine only had 800 miles on it. and yes there were a lot of gaskets and shop supplys.
Old 10-17-2017, 03:03 AM   #189
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
Will I be able to keep e85 if I go this route? Currently FBO 450rwhp. Looking into cam/heads and want to go with the gm set up, but I'm not sure if ill need a fuel lobe increase that would prevent me.
If I'm at e85 fueling limits with the cam, can I do injector and zl1 fuel pump, or does the bigger fuel lobe still need to be present?
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 10-17-2017, 06:43 AM   #190
USAFS197
USAFS197's Avatar
Drives: 2018 Audi TT RS
Originally Posted by BlackbeastSS2 View Post
Order
This Kit Includes:
Comp Cam phaser
Various gaskets
Tune
Did you end up using the stock converter for this or did you have to swap out? Also, either way, how is the street driving characteristics of the cam?
2018 Audi TT RS
2019 Audi RS3
About as fast as the TT RS
2019 Camaro ZL1 1LE
Sold
2018 Camaro SS 1LE
Sold
2019 Corvette Z06
Sold
Sold
Old 06-11-2018, 11:18 PM   #191
Chris C 1SS 1LE
Chris C 1SS 1LE's Avatar
Drives: 2017 1LE
I had two ECM for the Z28 and the Firehawk. No issues. You tune th extra one...
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube
Chris C 1SS 1LE is offline   Reply With Quote
Old 05-25-2019, 01:23 AM   #192
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
old post but im at my E85 fuel system limit with just my mods no cam or heads
Old 05-25-2019, 05:55 PM   #193
DFW1LE
DFW1LE's Avatar
That should not happen with FBO only!
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ
Old 05-25-2019, 10:45 PM   #194
JCunningham
Drives: 2017 2SS M6
my tuner says the injectors are open for 4.8ms and 5 is as far as they should go. stock cam. said if i go cam get 38 fuel lobe
Old 05-26-2019, 09:14 AM   #195
DFW1LE
DFW1LE's Avatar
I don't see why you'd be out of fuel with those mods on E85. Yes, if you cam it, I'd go for at least +32 fuel lobe.
Old 05-28-2019, 11:58 PM   #196
Poppacapp
Drives: 2017 Grand Sport
You can go higher than 5ms. Try to stay under 6ms. Pulsewidth will vary depending on where your tuner runs your A/F at. You should not run out of fuel with a FBO setup
17' Grand Sport
PP ported MSD IM, NW 103mm TB, ARH 2" headers w/ 3" catted x-pipe, PP Flex Fuel tune, Halltech CAI, some radials and a CATCHCAN!!!
Poppacapp is offline   Reply With Quote
