04-26-2011, 01:54 AM | #1 |
How do i spin my rear tires with manual transmission?
Any one know?
04-26-2011, 01:58 AM | #2 |
Butter Bar!
Drives: 2011 SS, 1998 Trans Am Join Date: Dec 2010
Turn off Traction Control. Do a nice hard launch and they'll spin easy. DO NOT do it on the street, just asking for trouble with that.
2011 Camaro SS, White/Orange, LSR Short Throw, CAI
1998 Trans Am, Red, H/C/I, 3200 CircleD Stall, full suspension 2004 GSXR 1k, Matt Mladin Edition |
04-26-2011, 02:03 AM | #3 |
Tracking control is off as always , it only turns on when the car gets slippery . I tried to do hard launch but all i hear is engine getting louder and louder . tires do not spin
04-26-2011, 02:10 AM | #4 |
Drives: 2010 Join Date: Apr 2011
04-26-2011, 02:14 AM | #5 |
Butter Bar!
That's not turning it off. It it's off a light will appear in the gauge cluster telling you so. Also sounds like you are burning you clutch up by revving it with the clutch partially engaged, unless this is how the traction control works. I have not tested the traction control on this car yet.
04-26-2011, 02:23 AM | #6 |
Got Boost?
Drives: 2011 1SS/RS M6 SLP TVS 2300 Join Date: Oct 2010
Turn off all the nannys, Rev up to about 4k and dump the clutch... youll have smoke in no time.
2011 1SS/RS M6
MOD List: SLP 2300 Supercharged, Flowmaster AT Cat back, aux 4 guage cluster, 12" kicker sub and Kicker Zx400.1 amp, PFADT Lowering springs CAI Inc. CAI, Hurst Short throw shifter, JBA 1 7/8 Long tube headers. Future Mods: 416ci stroker. |
04-26-2011, 08:11 AM | #7 |
Drives: 1969 & 2016 Camaro SS Join Date: Oct 2008
I cannot help you earn your man card, sorry.
Fquick.com/NineBall
04-26-2011, 08:21 AM | #8 |
Drives: 2010 2SS/RS IBM Black Polished Join Date: Feb 2009
Clearly you need to take the time to read your manual first. If you are spinning your tires with traction control on then the computer will bog it right back down. Once you learn how to control your nannies then you can hopefully learn to control your car. But do not do this on a road as the torque pull and or crown of the road can easily get you into a bad situation very fast. Grip changes between drivers and passenger side can also send you going in one direction very fast. Learn your car in controlled situations and locations. Track is best, parking lots would be next if there are no cars around. For some reason I cant keep my tires from spinning even in fourth gear.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
04-26-2011, 08:24 AM | #9 |
Drives: 2011 Camaro SS/RS Join Date: Dec 2010
04-26-2011, 08:43 AM | #10 |
Drives: 2010 Join Date: Jul 2009
04-26-2011, 10:53 AM | #11 |
love. my. car.
This is a joke right?
TC off 4k RPM quickly engage the clutch (release pedal) If your wheels don't spin, you're driving a 100 HP Ford Pinto.
04-26-2011, 10:56 AM | #12 |
TEAM LLT ! NY5thGEN
i think he is asking how to do a burnout not just spin the tires
04-26-2011, 11:36 AM | #13 | |
. So what's the proper way to do it ? |
04-26-2011, 12:18 PM | #14 |
Drives: Camaro 2015 RS CRM Join Date: Apr 2009
You're gonna burn out your clutch. Rev to 4k with clutch to the floor and pop the clutch. Be prepared to buy new tires.
IOM 2SS/RS manual
1100 - 4/7/09 3000 - 5/27/09 6000 - 7/17/09 See my Thread in New York Metro Area. http://www.camaro5.com/forums/showthread.php?t=33878 |
