09-13-2020, 04:47 PM | #1 |
Drives: 2010 Camaro 2SS/RS Join Date: Jan 2019
New exhaust need retune?
I recently installed a new exhaust system. After the installation the car acts like it has a miss or something is really wrong. It surges, pops under wide open throttle and the wideband is all over the place at idle and during a pull. I was told I wouldn't need a tune again, but nothing else was changed. All I did was remove the exhaust it was previously tuned with ( factory piping with no cats, resonators, or mufflers) and installed speed engineerings 3" xpipe exhaust. I already had their longtubes headers. Car is cammed, has a 3400 stall and gears.
Sent from my SM-G986U using Tapatalk |
09-13-2020, 05:00 PM | #2 |
Drives: 2010 Camaro 2SS Join Date: May 2016
Somethings wrong.You either have a leak or something else isn’t right.
Spark plug not firing or lead isn’t on etc. |
09-13-2020, 06:48 PM | #3 | |
09-13-2020, 07:19 PM | #4 |
Drives: 2015 Camaro SS convertible L99 Join Date: Nov 2016
Check the air flow sensor. Those things can go bad unexpectedly. No you do not neeed a tune after changing the mufflers. Also check for codes.
Corsa CAI w/Donalson Power Filter, BBK 1 7/8 headers, MF resonator, custom exhaust with Legato mufflers, mildly ported heads, TSP VVT 3.2 cam (whole package), 3.91 1LE gears, Circle D 3200 stall torque converter, B&M power cooler tranny cooler. Tuned by Casey TSP's tuner. 1/4 12.16 117mph with stock tires at 20 psi.
09-13-2020, 08:14 PM | #5 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Yes, if you add headers to your exhaust, you need a tune. Otherwise, no.
If your tuner is with his weight...he would still have you come in to double check things and diagnosis. So, If I were you, Id go back to my tuner and get some kind of handle on things.
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
09-14-2020, 11:27 PM | #6 |
Drives: 13' 1LE Join Date: Apr 2012
Its not the tune. Its either a cracked spark plug, unplugged wire, unplugged MAF, or other stuff like that.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
09-15-2020, 03:31 AM | #7 |
Drives: 15 Camaro 2SS M6 Join Date: Jan 2020
was there any welding during your exhaust install? a bad ground on the welder could fry electronics. you must have codes?
09-15-2020, 09:44 AM | #8 |
Drives: ZL1 Join Date: Dec 2016
Make certain that your O2 sensor extension connectors are good and plugged in, sounds like that loop might be open.
09-15-2020, 10:11 AM | #9 |
If I read OP's post right, he only replaced catback. He already had headers.
09-15-2020, 07:17 PM | #10 |
Drives: 2015 2SS/RS Vert Join Date: Jan 2019
Sounds to me, based on what the OP has said, something like a maf sensor, loose plug wire, or loose o2 connector is the problem. The fact that it happened when he changed the exhaust is just a coincidence, unless like "bottletalk" said, if there was welding done with a poorly grounded welder.
Proud member of the Motor City Camaro Club.
09-16-2020, 08:12 AM | #11 | |
