06-22-2020, 09:26 PM | #15 |
Drives: 1970 chevelle Join Date: Aug 2011
then corsa sport and done. No drone cold start is nice idle is better then stock and cruising down the hwy almost no difference but when you stand on it it sounds glorious
honestly exhaust sounds on youtube or any other video even the ones the manufacturers put up don't do them justice. I can take a video of any one of my cars and then play it back and it does them no justice on my iPhone 11pro compared to hearing it in person both in note and sound level
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car 2015 Z06 Z07 Daytona Sunrise Orange Metallic Dads Car 2013 ZL1 vin 963 Crystal Red Tint Coat/Black Wheels Exposed Carbon Fiber Insert 6 Spd Manual |
06-23-2020, 07:01 AM | #16 |
ember, you might be better off buying the Chevy Performance axleback for your Camaro as it is not offensively louder than the stock exhaust and is made by Borla and definitely won’t void your warranty since it has a GM part number and an upgrade to your OEM exhaust. Now if you want to upgrade to a quad tip exhaust then you have to change the rear diffuser/valence panel and get aftermarket quad tip without the NPP valves which the Corsa and Borla systems and others offer. The Chevy Performance system is dual tip like your stock system is on your car now. Hope this helps you.
06-23-2020, 07:10 AM | #17 | |
Hot Camaro
I can go either with or without the NPP actuators as I have a set to use. I'm happy to wire up the system myself as well. I want quad tips, though, and would be changing out the diffuser when I do swap over. Corsa advertises their "Variable" axle-back as offering a 12dB volume level difference between having the valves opened and closed. Being able to quiet it down when I want and open it up more when I want is the sort of thing I'm going for. |
