01-30-2018, 12:19 PM | #1 |
Drives: 2020 Camaro ZL1 Convertible Join Date: May 2014
Trunk Divider delete
I remember on the 5th gens, there was a mod where you could delete the cargo divider and not get the "extend cargo shade" error. You just had to be careful putting the top down if you had anything in the trunk.
Has anyone figured this out for the 6th gen?
-d00mz
2020 ZL1 Convertible in Shock -Bone stock (for now) 2017 ZL1 Convertible in Hyper Metallic Blue (sold) -stock 2014 ZL1 Convertible in Red Hot (sold) -Roto Fab Cold Air Intake with larger HX Rez -2.5inch upper pulley, solid isolator -Ported Blower Snout -ARH 2 inch headers and longflow off-road pipes -1000cc fuel injectors -NGK TR71X plugs -Catch Can -Dyno tuned to 600RWHP -All work done by Advanced Modern Performance |
01-30-2018, 02:08 PM | #2 |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
It appears to have something around the right snap on the shade, probably a magnet. You could probably work around that somehow if that is indeed how it actually works.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
01-30-2018, 02:10 PM | #3 |
Drives: 2017 Camaro SS Vert w/2SS Join Date: Aug 2017
Haven't heard of one. I would imagine you could just cut off the divider around the plastic pieces that attach to the posts at the top of the trunk. As long as those are connected together I wouldn't think you would have an issue. I wish Chevy would have made that divider differently so it attaches to the back of the seats and runs under the top when it's down, then makes a 90 degree turn up to those posts. That way we could more easily slide things under the top when down.
01-30-2018, 03:17 PM | #4 |
Drives: Hyper blue 1ss convertible 6 sp Join Date: May 2017
Is there any room under the top when down? Maybe room for a book or shirt lol.
01-30-2018, 07:27 PM | #5 |
Thank you Al Oppenheiser!
01-31-2018, 09:44 AM | #6 | |
Drives: 2016 Camaro 2SS Convertible Join Date: Sep 2016
1996 Camaro Z28 with T-Tops (Sold 10.22.16) 1986 Camaro IROC-Z with T-Tops (Sold) 1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present) 1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold) Follow me on Instagram - @gen6_2ss_vert |
03-11-2018, 06:11 PM | #7 |
Gang, I've figured this out!
After lots of experimenting, I was able to determine that the only thing that is required to be in place for the top to operate properly is the upper connector on the passenger side. Along with some of the divider material surrounding it. See pic for the example. I ended up taping mine in place to keep it snug against the sensor. Sometimes the wire loom for the trunk moves the part of the remaining divider, knocking off the alignment.
-d00mz
03-12-2018, 06:38 PM | #8 | |
Drives: 2017 1SS camaro ,2SS a 68 + 08 C6 Join Date: Dec 2017
03-12-2018, 07:21 PM | #9 |
Well if you take the car in for the divider recall, there will suddenly be an “extra” divider available. You just gotta keep the right one and cut up the other right one.
03-13-2018, 09:25 AM | #10 |
Drives: 2016 Z06 coupe Join Date: Dec 2016
I guess I don’t understand the reasoning. The divider protects the top from damage as it can’t go down when it’s not in place. Pull two snaps and lay it down and you have the whole area with top up. So mod it and I still have to open trunk and move objects to put top down. I see no advantage to this reasoning.
03-20-2018, 08:45 PM | #11 |
1. I don't keep anything in my trunk. Therefore 99% of the time, there's nothing the divider protects the top from.
2. With the divider in place, the trunk light is basically unusable. So keeping it up means on the rare instances where I do use the trunk, if it's at night, I can't really see anything in there. 3. On the rare occasions I did put it down, I only ever put it back up when I tried to put the top down and got the shade extend error. 4. The replacement part is $91. Cutting the divider (and ruining it without finding a solution) was a risk I was prepared to take. Since I was able to figure out how the sensor works, there is no risk. I can cut it further to clean it up and make it look nicer, and I'll probably do that on the next rainy weekend.
-d00mz
04-04-2018, 08:54 PM | #12 |
Drives: 2017 2LT Garnet Red Join Date: Dec 2011
04-12-2018, 02:29 PM | #13 |
05-20-2018, 10:10 AM | #14 |
Drives: 2017 Grey RS Convertible Join Date: Apr 2018
Since I leave my divider in 99% of the time, I'm planning on just cutting out most of the center of the divider and replacing the deleted material with a net. That way the light will be effective. I will post a picture when I'm done.
