Old 01-12-2023, 05:17 AM   #15
Redlinez
Shifts under load
Redlinez's Avatar
Thanks for that input! I'll look into the Amsoil as well.
22 Suzuki GSX-S 1000GT blue
Old 01-16-2023, 09:30 PM   #16
MatthewAMEL
MatthewAMEL's Avatar
Drives: 2023 CT5 Blackwing
Originally Posted by N Camarolina View Post
I seem to recall that you purchased Tremec's fluid at least once before, but I can't remember what your feedback was on it's performance. Perhaps you can share now?
I ask because Tremec's fluid is considerably higher viscosity than the OEM, isn't it? Which would potentially provide higher protection on the track, but also more clunkiness on daily drives upon start up and 1st mile or so of driving (especially in cold weather)?
Please forgive me if you've shared this previously.
I have been running it for nearly 3 years now. DD (low miles) in Florida and LOTS of AutoX and Track time.
Rarely gets below 40F here, so I can't really comment on how it behaves in low temp environments. The fluid gets changed twice a year and shifts well and makes no abnormal noises.
I can tell you that I believe in it and TREMEC enough that I am switching the fluid in the Blackwing to the HP-MTF when I hit 1,500 miles.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
Old 02-25-2023, 09:45 PM   #17
mano_camaro
IYAOYAS
mano_camaro's Avatar
Drives: 22 1LE 2SS M6 Riverside Blue
during winter i experience temps around 20's & 30's and your assessment is correct. when is cold, the Tremec fluid makes it clunky, however on warm days 60 deg + it is very smooth.
I mostly have to start from 1st and go straight to third gear skipping the 2nd gear on the first few minutes of driving, even third gets clunky a lot of times.
2022 Riverside Blue Camaro 2SS 1LE/ PDR
2020 Red Hot Camaro 2SS 1LE/PDR /Sold
2018 black Camaro 2SS M6 Redline Edition/Traded
2016 summit white Camaro RS V6 M6/Traded
mano_camaro is offline   Reply With Quote
Old 02-27-2023, 12:16 AM   #18
N Camarolina
N Camarolina's Avatar
Drives: 2021 2SS 1LE
Thanks for the useful info about the Tremec fluid. Not living in a "warm all the time" climate, I think I'd be frustrated with the clunky shifting when the fluid's cold. Thus, will plan to stick to the OEM.
N Camarolina is offline   Reply With Quote
Old 02-28-2023, 10:28 PM   #19
havelegs
havelegs's Avatar
Drives: '23 LT1 A10
Soooo, is 88861800 correct for the m6?
havelegs is offline   Reply With Quote
Old 03-10-2023, 01:37 PM   #20
haggler
haggler's Avatar
Drives: '23 2SS RSblue 6MT, sold '19 ND2
I wanted to share this article I found:
https://txdrivetrain.com/fluid-type-...56-tr6060-faq/
I have no experience with them but it seems like they rebuild these transmissions. Basically they state to use non-synthetic fluid in these, which the OEM part is (dexIII) and products like Valvoline Dex/Merc which is DexIII equivalent.
'23 2SS, 6 speed, NPP, Copper-free brakes, 56V Carbon Flash Rims, Riverside Blue
1LE sway bars
EOS front splitter
5-6-22:1100,
7-19-22: 3000,
8-3-22: TPW 8/15/22,
10-4-22: ETA 10/13/2022
10-15-22 6000
haggler is offline   Reply With Quote
Old 03-10-2023, 05:27 PM   #21
N Camarolina
Thanks for providing this. They don't provide any data to back up their position, but they at least have a theory and presumably some experience over the years that might support the theory.
Since both their theory and GM call for using OEM or non-synthetic ATF, that's what I'll do. Not sure if the syncros will indeed be more short lived with synthetic ATF, but why take the chance if you intend to own your SS for several years.
Old 03-15-2023, 01:41 PM   #22
lucabelga
Drives: Camaro 1SS
Originally Posted by MatthewAMEL View Post
Based on the Data Sheet provided by Tremec:
Applications:
Recommended for motor vehicles with manual gearboxes that require GL4 75W85 MTF, synchromesh, or DEXRON®-III/MERCON® fluids.
Not recommended for automatic transmissions or hypoid gear differentials.
In this way, it is natural to GM to apply Dex III ATF fluid from the factory, but can't see no harm in using, for example, Amsoil fluid as it complies with the Viscosity and API Specs
lucabelga is offline   Reply With Quote
