TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 07-02-2022, 07:24 AM   #1
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
Tell me about the clutch pedal spring, Are they worth Modding?
Hi, I keep hearing about the clutch pedal springs being removed or another added and other ideas, Can you tell me a bit about it and should I do anything? I am not a fan of the current ( OEM ) Clutch feel.
Here is one option.
https://www.lingenfelter.com/product...l#.YsA42oTMJEY
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS
Stainless Works Ceramic LTH/HiFlo Cats
SCT X4 Dynosteve,
Hotckis 1" Springs & Chassis Max Brace
BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings
Pedders Radius Rod Inserts Strut tower brace
Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 07-02-2022, 09:25 AM   #2
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
I just got rid of the helper spring on the clutch pedal over 4 years ago...made a major improvement IMHO.
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
frankwjr is offline   Reply With Quote
Old 07-02-2022, 09:45 AM   #3
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
So does removing the helper spring make depressing the clutch ezer and smoother all the way down?
camguynj is offline   Reply With Quote
Old 07-02-2022, 10:51 AM   #4
frankwjr
frankwjr's Avatar
yes...
Old 07-02-2022, 12:08 PM   #5
Joe.G
Joe.G's Avatar
I have not looked at it, is it easy to unhook to try it?
SCT X4 Dynosteve,
Old 07-02-2022, 12:23 PM   #6
frankwjr
frankwjr's Avatar
I believe I used a pair of needle nose pliers to pop it out...pretty straight forward once you stick yer head down there..
And for clarification I also have a Monster twin disk, tore up the stock unit drag racin...
Old 07-02-2022, 02:38 PM   #7
Rob3D
Rob3D's Avatar
Drives: Car
Yup. Much smoother and much better quick shifting…no more bouncing because the spring changes the amount of pressure you have to use between fully pressed and extended. I’m no enjinear but I’m a firm believer it’s only there to prevent morons who ride the pedal from damaging the clutch. That’s why it’s only applying pressure to the top 30 degrees of arc. It’s a actually enjeenius. There’s no telling how much money on clutch recalls/warranty work it saved.
Rob3D is offline   Reply With Quote
Old 07-02-2022, 06:59 PM   #8
demonspeed
not afraid of the wall
demonspeed's Avatar
Drives: Camaros
Mine was removed a while ago. Much better feel - smooth and linear.
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100
Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z
demonspeed is offline   Reply With Quote
Old 07-02-2022, 09:03 PM   #9
Joe.G
Joe.G's Avatar
So what does the Spring I linked to above do?
SCT X4 Dynosteve,
Old 07-03-2022, 12:30 PM   #10
demonspeed
demonspeed's Avatar
Drives: Camaros
Some people get a sticking clutch pedal where it won’t come off the floor. That return spring is just a bandaid to actual issue. I’ve never had the occurrence with my 5th Gen after having separated the reservoir, added insulated clutch line, and high temp DOT4 fluid.
10/13/22: 1100
Old 07-03-2022, 12:38 PM   #11
Joe.G
Joe.G's Avatar
I did remote Reservoir and Dot 4, I was just wondering if the spring made the Clutch pedal feel any better, Sometimes I feel like I don't know how to drive when I stall for no reason. I think I may remove the Helper spring GM Put on.
SCT X4 Dynosteve,
Old 07-03-2022, 01:10 PM   #12
demonspeed
demonspeed's Avatar
Drives: Camaros
It’s easy enough to reinstall if you don’t like how it feels without
10/13/22: 1100
Old 07-03-2022, 02:43 PM   #13
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
Don't hesitate at all!
Throw out that nasty piece of junk and replace it with a tension spring Lingenfelter!!!!!
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune.
George-CZ is offline   Reply With Quote
Old 07-03-2022, 09:00 PM   #14
Joe.G
Joe.G's Avatar
That what I am not sure of if I should add the Aftermarket spring. I think I may.
SCT X4 Dynosteve,
