06-16-2022, 02:57 PM | #1 |
Drives: 2010 Camaro 2SS Join Date: Apr 2011
SS to Z28 Axles?
2010 Camaro SS LS3
Already swapped the differential to 3.91 from a 1LE. The axles and hubs are stock. I have the Z28 outer hubs (25954415) to install. Would like to purchase Z28 axles before GM discontinues everything. Can anyone confirm this setup will work? Thanks, John |
06-16-2022, 04:07 PM | #2 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
yes....and good luck with finding the axles.
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
06-16-2022, 04:14 PM | #3 |
Per THIS THREAD, as long as I understand it correctly, it should work.
https://www.camaro5.com/forums/showt...=518429&page=2
2010 Camaro 2SS
2018 Charger GT+ 2005 Cavailer LS S/C - Sold '87 HD FXRT - Wrecked pending repair |
06-16-2022, 05:19 PM | #4 |
Drives: 2011 Camaro 2SS/RS Join Date: Jan 2011
They will fit. I have the Z28 hubs and axles. I found both in stock at GMPartsGiant.com
You might want to order ASAP though, cause one side is discontinued.
Allen
2011 Camaro 2SS/RS |
06-17-2022, 10:25 AM | #5 |
Thank you for the quick responses.
06-17-2022, 06:50 PM | #6 |
Drives: 15 Camaro 2SS M6 Join Date: Jan 2020
why z28 axles? why wouldnt you go with another brand?
I plan on swapping axles when I rebuild my diff and cradle bushings, any info that would help my decision is appreciated! |
06-18-2022, 11:21 AM | #7 |
bottletalk,
For me it came down to cost. Aftermarket was way more expensive. I plan on a cam swap in the near future and wanted to upgrade the weak 2010 SS suspension and driveline components. I don't race or track the car, but with my car approaching 100,000 miles, I figure the Z28 axles would be a decent "upgrade." |
06-18-2022, 02:10 PM | #8 |
thanks snags18,
makes sense, have you upgraded your driveshaft or have plans on doing it? after I finish my rear end and get some coilovers in that's my next step. I don't track but I'd like to take it to the strip once I'm done so performance isn't that much more important to me then drivability and being reliable.....close, but I don't want to be the guy broken down after I let loose haha. |
