Old 01-24-2021, 12:04 AM   #1
1ssa_camaro
Drives: 2017 Camaro 1ss A8
Does wheel size affect tune
I currently have long tube headers with off road x pipe, intake and a flex fuel tune. I was dyno tuned on the stock wheels that come on our cars. I wanna upgrade to 305’s in the back and 285’s in the front or some d5 forge stars with 305/45/17’s. Will this affect my tune at all? It might be a dumb question, but I’ve heard how it can affect it. Thanks
1ssa_camaro is offline   Reply With Quote
Old 01-24-2021, 01:09 AM   #2
delthawk5
Drives: 2019 2SS Crush
wut
delthawk5 is offline   Reply With Quote
Old 01-24-2021, 06:22 AM   #3
SS_1LE
Drives: 2020 SS 1LE
Might affect your speedometer accuracy but that’s about it
SS_1LE is offline   Reply With Quote
Old 01-24-2021, 08:08 AM   #4
s346k
s346k's Avatar
Drives: like an old lady
what's the difference in tire height? as long as it isn't much i can't see the new wheel & tire causing much trouble. if it's shorter you might run into shifting issues.
need those automagic guys in here.
Old 01-24-2021, 08:21 AM   #5
Invertalon
Drives: 2021 2SS
Changing tire size, tire mass, etc... Will affect how much power is required to overtake the rotational inertia differences. So a larger, heavier rim/tire combo will take more work from the engine than a smaller combination. The lighter, the better maximizing how much HP/torque gets to the road. Don't think this would result in a tune difference though, just potentially hurt your actual real world performance if the wheel/tire combination is heavier than what was there before, depending on losses due to tire width and grip and all that.
Invertalon is offline   Reply With Quote
Old 01-24-2021, 10:13 AM   #6
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
Wheel and tire mass/inertia differences would have to be massive to have any measurable effect on power to the ground. Wheels are spinning so slow relative to the crankshaft that they aren't going to sap power unless we're talking about 20lbs difference or more. Tire diameter does make a difference to overall gearing, but the OP can upgrade to wider wheels/tires and stay within a close range on diameter if he chooses sizes carefully.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 01-24-2021, 01:13 PM   #7
1ssa_camaro
I was looking to upgrade to 305/30/20 20x11 in the rear and 285/30/20 with 20x10 in the front
Second option is keeping the stock front wheels and tires and adding some d5 forgestars with 305/45/17 mickey thompson et street r's
Old 01-24-2021, 01:41 PM   #8
grampa_ss
grampa_ss's Avatar
our cars come with 275/35/20 rears....that's a 27.6. the 305/45/17 are 27.8. not even 1mph difference up to 90mph. So that's ok. But I'm not sure about putting a 285 on our 8.5" front wheels. Maybe someone else can chime in on that.
Old 01-24-2021, 03:10 PM   #9
Msquared
Msquared's Avatar
No, that would be a terrible idea. But the OP just said he would get 20x10 front wheels if he goes to a 285/30/20. So he's fine.
Matt Miller
2020 SS 1LE
