01-23-2021, 01:50 PM | #15 |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
It’s funny you bring this up. I just woke up to a flat rear passenger side tire this morning. Brand new tire and perfect tread and two nails punctured it in the same spot in the repairable area making it unrepairable due to the hole being too large.
I have an air compressor at home so I can always refill it but I’m going to have to replace the tire. |
01-23-2021, 02:19 PM | #16 |
Drives: 2016 2SS Convertible Join Date: Dec 2019
Does it fit within the well below the floorboard? I have a Vert, the trunk is only big enough for a Playmate cooler and a small duffel bag! If I get a flat and change it with a spare, I'd have to put the normal wheel/tire in the backseat!
Hyper Blue/Ash Gray A8 Magnetic Ride Control Dual Mode Exhaust 2019+ version Split Spoke Silver Wheels Navigation Silver Rally Stripes |
01-23-2021, 03:17 PM | #17 |
Drives: No Camaro :( Join Date: Apr 2013
01-23-2021, 03:39 PM | #18 | |
Drives: 16 Camaro 1SS & 82 Silverado C10 Join Date: Mar 2009
Good point about the verts I can't imagine a trunk w less height than mine. Our trunk is big just narrow opening, but I can get this spare in easy and still have about 10" of height inside, I'll measure.
Ordered 1SS Black on Black, M6 in late summer 2015.
Hurst shifter, Soler Performance ported TB. |
01-23-2021, 04:00 PM | #19 | |
You can get two Playmate coolers in the trunk with the top down, that's it! The problem for me is that I bought the car for fun and to take drives to places like northern Michigan. I don't want to be caught with a flat where it could take hours to get help, or rely on run-flats for hundreds of miles to get somewhere where a shop has the right equipment or even have the right 275/245-20's to replace. I seriously doubt many places in Michigan's U.P. carry tires like ours in stock!
01-23-2021, 04:11 PM | #20 |
Drives: 2017 1SS Hyper Blue Join Date: Apr 2017
Gonna have to replace it with an electric car pretty soon anyway, so probably just abandon it and Uber it home.
01-23-2021, 04:25 PM | #21 |
Drives: SWXXZL1 Join Date: Jul 2020
Complete tire plug kit, small compressor, aluminum scissors jack, ZL1 ADDONS pucks, and a complete tool bag. I've always carried this stuff in my four Corvettes and now the ZL1. Luckily, never had to use them. Better to have it and not need it...
"Joe" does a hilarious impression of a slinky toy on stairs.
01-23-2021, 04:28 PM | #22 |
1SS coupe trunk, about 10 in above modern compact spare. Too bad Chevy didn't make a well deep enough for a spare. I like the principle of run flats, they just felt like rolling on wooden barrels to me.
I can still pack a lot of soft travel bags in there or groceries. In hibernation now though. I put the compact jack under the floor.
01-23-2021, 04:42 PM | #23 |
What is the OD of that aftermarket spare vs the oem rear tire? If different by to much, having to use it might have a negative effect on the rear end, would it not?
01-23-2021, 05:08 PM | #24 |
plug kit,inflator,and triple A card /cellphone if all else fails.
01-23-2021, 05:28 PM | #25 | |
376 cubic inches of fun
Then I remembered the old trick of turning on the headlights for 30 seconds to stimulate the battery. I got the car started...just barely, and got the battery replaced in the morning. If I'de had a flat, I would have been stuck until the next morning...with wife and kids, BTW. So...my advice is, if you have a garage queen and the drag strip is around the corner, then fine, get rid of the run-flats. Otherwise, don't. I have carried a full sized spare strapped down in the trunk of my Gen5, but I understand the Gen6 doesn't have the steel tie downs and maybe a full sized tire doesn't even fit. When this pandemic shit is over and I resume road trips in my Gen5, I'm gonna throw some run flats on it. |
01-23-2021, 05:56 PM | #26 |
Drives: 2021 Camaro LT1 Join Date: Sep 2020
01-23-2021, 10:29 PM | #27 |
Good point about the LSD and tire sizes, I checked, the modern spare is about 26" dia. but my stock tire rear is about 27" dia. If I had a rear flat, I would put spare on front and move front to back, to not toast the LSD limping home. I changed my diff fluid around 2k miles and it was dark and thick, looked like fine material in it. I changed again around 15k and it seemed almost clear still, maybe didn't need change then.
01-23-2021, 11:00 PM | #28 | |
Looks like I’m stuck with RoF’s or the emergency kit for non-RoF’s for my vert. Haven’t had a flat in many many years until last summer when my XT5 picked up a pointed lag bolt just before I got on a freeway. Had to change it out in a parking lot as it went fast after the bolt ejected itself! Luckily made it to an exit before all the air was gone!
